Question about Emerson 1100 Watt Black & Stainless Steel Microwave Oven & Grill MWG9115SL, 1 ea
My Emerson microwave is only a few months old. I clean it with each use. My problem is there is a rotten odor when I open the door. Is this the grill unit? Can't take apart to clean. Help.
How can I remove the horrible odor? I tried nuking a lemon in water. It did not work. Ready to toss out the window. I paid $100.00 for it at Walmart.
    Top Expert:
  • Emerson Master
  • 14,553 Answers
It should have a warranty, consider pursuing that route.......if possible I would talk to Walmart to see if they will give credit for it being returned so you can get a different brand..........
Posted on Nov 05, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: Door Window steams up on Microwave
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
Posted on Nov 05, 2007
  • 89 Answers
SOURCE: Emerson microwave light out
There is a way but.... you will have to remove outer cover generally held on with screws at rear and under microwave be sure the oven is unplugged and when you take cover off there is a capacitor in there thats holds a charge stored even when oven is unplugged so dont touch nothing except the light bulb would prefer if you dont have much electrical experience to take to repair shop or have someone do it who has a little electrical knowledge hope this helps
Posted on Sep 05, 2008
ButtFuzz
  • 463 Answers
SOURCE: Microwave exploded.
Did it make a popping noise, like a .22 cal pistol? Probably one of the larger capacitors on the power supply blew up.
Posted on Mar 06, 2009
WGCowen
  • 5 Answers
SOURCE: Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Posted on Jul 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Broken door on my Emerson microwave (MW8985W)
You can order the outer panel. Its available at searspartsdirect.com for about $41. Just type in your model number and look under the "Door Assy" heading. To replace, just follow these steps:
You have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and any screws that may be holding the outer panel in place. Some panels are simply snapped in place.
Remove the broken panel and install the new one. Re-install the door handle and re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you
Posted on Aug 28, 2009
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
No Power - Emerson MW8773SL Microwave
LOOKK FOR FUSE UNDER SCREWED IN PANEL!
Dec 10, 2008 | Emerson MW8775W Microwave Oven
Odor of burned popcorn!!
The smoke has permeated the works, so a more aggressive cleaning will be needed.
There are many good suggestions for cleaning and deodorizing microwaves here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Emerson MW8119SB microwave wont stop running with door closed
It should have a one-year warranty on parts and labor.
I'd call Emerson at 1-800-695-0098 to find your nearest authorized service center to have it fixed free.
It's probably a bad door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Emerson MW8778 Microwave Oven
Blown Fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Emerson 1000 Watt Microwave
There is a good possibility that microwave energy is leaking near the magnetron tube, or some other high voltage electrical problem is occurring. I would recommend having it tested by qualified microwave repair technician. A few things you can do....
-Make sure the door seal is clean and no corrosion.
-Check the interior for rust spots or holes and make sure it's clean inside.
Jan 16, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
My Emerson MW8115FS 1450 Watts
hi your door has hooks which activate switches.one of the switches is called the monitor switch .the purpose of this switch is to close the mwave circuit[complete the circuit] indicating your mwave is safe for use.at present your mwave circuit is open therefore your functions arenot working .check if door hooks are making contact with the switch ,check if the swith is testing continuity.ihope ihave been of assistance let me know cheers
Feb 05, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
See answer here: http://www.fixya.com/support/t133065-emerson_mw8115
My Emerson MW8115
Hopefully it was not an unheated storage area! Moisture and contamination can get into the controls from condensation due to big changes in air temperatures in areas like unheated storage units or garages. That being said, the most common causes of a failure to heat are in order: - bad door switches or door switch mounts - loose connection at the magnetron - problem with the control unit - bad magnetron or other high voltage part At our site, we have critical safety information, info on door switch diagnosiss and replacement, and disassembly information. You can find us via our listing here on FixYa: http://tinyurl.com/yzjozk
Emerson 1100 Watt Black & Stainless Steel Microwave Oven & Grill MWG9115SL, 1 ea Logo
90 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
