I HAVE 60 ' INCH FATBACK WHILE THE TV TURNS ON THE SCREEN THAT TELLS YOU , SETTINGS , STAYS ON UNTIL IT WARMS UP ....YOU GO TO YOUR REMOTE AND HIT MENU , IT DISAPEARS....BUT ONLY WHILE ITS WARM .
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Got a heat related issue likely on main signal board---might be able to localize it (suspect a flat pack chip) with a hair dryer to heat the board just a bit.
Posted on Nov 05, 2012
  • playerpr30
    playerpr30 Nov 20, 2012
    WILL I HAVE TOO DO THIS EVERYTIME?????
Coldcut
  • 1554 Answers
SOURCE: sharp aquos lc26sh12u no menu screen appears
as you have a good screen, I would check ebay for the display controllers as there are so many available after shipment drops and kids with hard toys.
what you have been troubleshooting so far is analog , now its likely a digital issue , all you can look for is the the cpu is running,
is it getting the 5v + and the say 20 or so volts.
Posted on Feb 04, 2008
dsacco86
  • 1077 Answers
SOURCE: when i turn my tv on the screen flashes digital then turns off
Basically, the TV is trying to power up the screen. If it fail to do so, the TV will automatically turn itself off to protect other part from being damaged inside. The problem is going to be the Backlight Inverter Board. It's the circuit board that supplies power to the screen. You can usually find a replacement board at a good price at Shopjimmy.com
Posted on Aug 20, 2009
Testimonial: "thanks for the help i was able to compare prices for when i take it to the tv repair guy so he dosnt screw me on the cost of repair!"
SOURCE: the tv menu keeps popping up and i have to use the remote to exit
did you get this to stop???
Posted on Sep 23, 2009
BoiseLCD
  • 63 Answers
SOURCE: THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Posted on Dec 16, 2009
  • 639 Answers
SOURCE: remote wont work and can't acess menu with tv
Turn your Sony Bravia on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
  • 2 Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
  • 3 Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
  • 4 Release the up arrow button. Once the TV turns itself back on, it will restore your Sony Bravia to its factory settings.
  • Read more: How to Reset a Sony Bravia TV ' eHow.com http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html#ixzz1Cn2noiTF
    Posted on Feb 02, 2011
    Sanyo p42840-06 channel menu comes on then goes off led power stays on.
    Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
    Dec 07, 2016 | Sanyo Televison & Video
    Reprogram the URC-9910 universal remote for VIZIO E3D420VX
    Universal remote code to check with Vizio TV is [0081.
    Direct Code Entry
    1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
    3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
    4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. If you want to get more details and codes to different remote controls, check this.
    Dec 30, 2012 | One For All URC-9910 LCD Remote Control
    When you turn the tv on it goes to the settings screen and you can't get a picture for about 20 minutes until it warms up
    Fist is contact Philips to see if this (with the model number) is a known issue or if there is a software upgrade available for this set.
    Apr 08, 2012 | Televison & Video
    My emerson 20 inch flat screen tv is encased in a dog house for outdoor use. I can't get to the back to see the model number and I want to buy a remote control for it. Is there a universal emerson...
    You should be okay just buying any generic universal remote. Any remote requires programming to work with a specific TV, but universal remotes are easily programmable. The instructions included with the universal remote will detail how you program that remote to work with your TV (usually along the lines of simply putting it in programming mode, and pressing the power button until it turns your TV off, and then locking it in)
    Mar 23, 2011 | Emerson EWF2006 TV
    How do i program my rca remote to my 42 inch samsaung tv
    you can try a code search
    1. Turn on the tv you want to program.
    2. Press and hold both the button for the component along with the power button until the light comes on and stays on.
    3. Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
    4. Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on. You may have to do this up to 10 times until it searches through the bank of ten codes sent.
    5. Press and hold the stop button until the light goes off. This saves the code.
    Mar 03, 2011 | RCA 3-Device Universal Remote
    I have just purchased a used JVC D series tv and the screen rolls until tv warms up what can i do to troubleshoot this issue myself?
    got a jvc d series floor model projection tv, it turns on but it rolls till it warms up what is the problem...
    Oct 01, 2010 | JVC Televison & Video
    I need a code list for a Brightstar remote to a Panasonic T.V
    To program the Brightstart BR100P-D
    Turn on the TV
    Press and hold cod search until the light stays on (about 5 seconds)
    Press power until tv turns off
    Press enter to save code
    Oct 25, 2009 | Universal Remote Control Remote Control
    I have a hughes hrmc-11 remote control and i have a proscan flat screen tv i was wondering if there is a code so i can use the hughes remote to ctrol my tv
    auto code search.
    hold down the tv button and mute button until the tv button light stays on. press the channel up button(this will cycle thru codes) test with the power button. process may take a few minutes. when the tv turns of press the tv button to store code
    Jan 02, 2009 | Hughes HRMC11 Remote Control
    Looking for programing codes
    Turn TV on. Press and hold [Code Search] until LED stays lit. Repeatedly press [CH +] until the channel changes. Press [Enter] to save code.
    Dec 13, 2007 | Universal Remote Control Remote Control
    Televison & Video Logo
    175 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
