Question about Audiovox Sirius-xm Xdnx1h1 Onyx Dock & Play Radio With Home Kit
My xm radio always say check satelite antenna when turned on what is the problem
All of the bars are showing to have a good signal
    Top Expert:
  • Audiovox Master
  • 14,553 Answers
You might have to contact customer service about this issue.
Posted on Nov 05, 2012
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Cant receive my channels i have had xm resend the activation signal 7 times and still wont work
First, turn the radio on and off using the POWER button on the radio - do not just turn off the car or unplug it. Next, make sure your 'sleep timer' isn't set. Next, check your antenna signal level and make sure you're in a location that has at least 2 bars - move until you do.
Now, make sure that you leave the radio ON Channel 1 for at least a half an hour. You should then have your channels back - when you do get all your channels back, turn the radio on and off with the POWER switch, not by unplugging the unit, or pulling it out of the dock or turning off the car. Okay?
Oct 27, 2009 | Delphi XpressRC XM Satellite Radio...
No Signal on XM Radio - Goes in and out of Signal
xm will not hold signal but if I move the antenna wire around inside the vehicle it will suddenly come in clear as day
Sep 02, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
XM Roady is non functional
turn ignition on and disconnect your car battery then leave it on until its done loading if it still there then call xm and have then send an update good luck....
Dec 30, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
XM Radio
My XM just recently started to cut out in certain locations that had no problem before. It seems to be getting a good signal the screen display does not cut out. I lose volume and get static just in certain spots. Anyone know where I should start looking for a fix.
Jun 26, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Delphi Roady XT Quit Working
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Oct 31, 2006 | Delphi Roady XT XM Radio Receiver
Cannot Get Antenna To Pick-Up Signal
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
Audiovox Sirius-xm Xdnx1h1 Onyx Dock & Play Radio With Home Kit Logo
105 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
