Question about Refrigerators
KitchenAid KSSC42FJS00 not cooling
Fridge side not cooling, freezer side is within norm. Have cleaned the coils on the top of the unit. Looking for how to access the evap coils to clean and check the air flow fan.
  • Scott McGlothin
    Scott McGlothin Nov 05, 2012
    Here's what has been done: Cleaned coils on top and bottom of unit. Have inspected the evap coils and frost only appears on the top of row of coils. Evap fan is working properly as well as Damper door. When I pulled the Thermistor and placed it in a cup of ice for 10 min the reading was 9.61 kohm, from what I've been reading this should be 16.3, could this be the problem? Temp in the freezer is 0 degrees, temp in the fridge is 50 degrees
Have you checked the condenser as i never seen this fridge but it if it has a fan cool condenser and it may need cleaning this will make a difference. Also worst case it maybe short of gas when it is running check the suction side pipe that goes into the compressor it shouldn't be to hot if so maybe it is short. As im Aussie i don't see this monster of a fridge but i hope this helps.
Posted on Nov 05, 2012
abhishek33
  • 1239 Answers
SOURCE: After cleaning coils and in back of fridge, it appears that the defrost keeps cycling every 5 minutes
hi
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Posted on Oct 10, 2008
  • 306 Answers
SOURCE: Access to clean coils on kscs25inss00
You need to get a bottle brush they are about 18" long maybe longer and made for getting into these area's to clean the coils. My frig is set up the same way and hate it. Cause when they are that dirty cause's so many things to happen all bad. I have used my air compressor to blow them clean and then chase little dust bunnies around the kitchen. I have been thinking about this same problem for awhile now and bottle brush is the best option for now that I have heard of. ken
Posted on Jan 03, 2009
praky16
  • 744 Answers
SOURCE: KitchenAid model no. KSRS22FGBL03 Fridge is
hi u didnt rate for my chat?
Posted on Jun 02, 2009
  • 118 Answers
SOURCE: PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Posted on Aug 05, 2009
  • 2696 Answers
SOURCE: fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Posted on Mar 22, 2010
Describe your Superba Architect KSCS25INSS Side by Side Refrigerator Problem - fridge has power - lights on - but not cooling freezer or fridge - no noise coming from fridge -
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | KitchenAid Superba Architect KSCS25INSS...
I have a side by side Kitchenaid fridge (Model KSRA25ILSS02). Problem is that the fridge side is not cooling proberly. I have cleaned the consdenser fan and coils on the bottom of the fridge and have...
turn temp all the way down in fresh food side and open the door but hold the door switch closed. damper should open when unit finds temp too high. Could be damper or control if it does not open.
Apr 14, 2011 | KitchenAid Refrigerators
K68625FJBL01 KitchenAid Sidebyside Refrigerator Freezer compartment was not cold yesterday so I cleaned the dog hair off the coils and the freezer is still warm and fridge side is not cold enough now. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Fridge not cold and freezer not freezing
Cleaning the dust from the condensor is what I would have done first. the second suspect is the thermostat. When they go out, they either make the refrig freeze up or just go out. the last thing would be the compressor to go out. Cleaning the condensor coil is recomended at least once a year. A good toilet brusk and "Dawn" dish soap works great! The last thing is of corse, a service call. good luck,Lloyd
Jun 01, 2010 | KitchenAid KSCS25FKSS Side by Side...
Fridge and freezer not cooling properly. bottom s...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
68rjszndh
May 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a Kitchenaide side by side refrigerator thats not cooling.
Check the coils underneath the fridge. Check the coils in back if accessible. Clean the coils if covered in excessive dust it may help. Make sure the vent on fridge side isn't blocked or plugged.
Nov 28, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Fridge is side by side Kitchenaid. Quit cooling, I defrosted and cleaned the coils. Turned it on fan is working, cool air blowing underneath the refrigerator. but can't tell if it's cooling the...
heatman101
Nov 16, 2009 | Kenmore 57182 / 57184 / 57188 / 57189 Side...
Freeze works fine, food side at 50 degrees.
Is there a fan that blows air over the cooling coils in the freezer? Not sure if side-by-side fridges have this. This was the reason for my top freezer / bottom fridge. Air was not being blown around the freezer and down into the fridge.
Feb 19, 2009 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
