Question about GoPro Digital Hero 3 Digital Camera
Hero 3 only records for 14 seconds every time
Every time I take a video it will only record for 14 seconds then shuts off. I have to keep hitting record for it to start again. Very frustrating
  • 1 more comment
  • anthony_phan
    anthony_phan Jan 02, 2013
    Mine stops after 7 seconds. Tried different recording resolutions/framerates with the same results. I'm also using a Sandisk Ultra 32GB card (class 10).
  • tombothemong
    tombothemong Jan 03, 2013
    mines doing the exact same
  • tombothemong
    mines doing the same thing
Delete all files and reformat your SD card using the settings option on your GoPro Hero camera. I did and all is back to normal.
Posted on Feb 20, 2013
Turn off your pro tune
Posted on Jan 06, 2013
  • 4 Answers
Did u find a sol mine doing the same
Posted on Dec 27, 2012
  • lowell_hamil
    lowell_hamil Jan 06, 2013
    fixed the problem it was my memory card was only running a class 4 bought a class 10 have had no more problems
Time Lapse photos
This is not a gaming issue.
Mar 10, 2014 | GoPro HD HERO 3 Silver
Hi , i have a problem with my gopro hero.. when i want to record a video , it records very fastly.. for example we record 1 minute , it records for 3 seconds.. i have the sdhc 8gb class 4 memory stick.....
this could be a problem on your pc, I have had this issue on a notebook but when i went onto my pc with more ram it worked ok. also it may depend on which codec is being used on your pc to view the mpg4 files, I have also noted that as well as fast speeds that the sound was out of sync.
May 15, 2011 | GoPro Digital Hero
When i am in video mode, my camera only records for 60 seconds then it stops and i have to hit record again. Is there a setting i need to change to fix this problem? its very frustrating
Is it EXACTLY 60 seconds EVERY time? If so, it sounds like a preference setting (probably default). Try going to the Menu section and look for a "Setup" routine and see if there is a "Max. Record Time" (or something similar) setting. Change as desired. Usually there is a choice for the maximum capacity of your recording media, SD card or whatever. If it starts out ending at 60 seconds and gets progressively shorter with each recording cycle, it may need recharging. Good luck. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
Jan 23, 2011 | GoPro HD Hero 960 Video Camera
For my first generation GoPro camera, do I need a memory card with a class rating higher than a 2 to have better quality videos. Also my camera seems to have a mind of its own and shuts down after about 30...
A Class 6 memory card is required for recording HD quality video. Not sure if yours is HD or not. Anything lower than Class 6 (such as Class 4 or Class 2) will result in recording issues and possibly skipping some video here & there.
As for the 30 seconds of filming limit...
1) It may be the memory card...that is if it's lower than Class 6. As a rule of thumb, when it doubt, buy Class 6 or better. Class 10 is the next step up, but it's a quite a bit more expensive.
2) Make sure you are using good, Lithium batteries...not Alkaline. Alkaline batteries will shut the camera down after a very short period.
Here are more tips on shortened recordings from GoPro's Website, followed by their Support Contact Info:
The batteries do not last very long.
  • It is not recommended that you use Alkaline batteries. Lithium batteries have the best results and longest battery life. Rechargeable NiMH are another option in mild weather.
  • Is it cold out? Battery life can definitely be affected by the cold! Please make sure you only use Energizer Lithium batteries in the cold, as any other battery type will perform poorly. In cold temps, you can expect about half of the normal run time when using the Energizer Lithium batteries.
  • Still having shortened records with a good set of the recommended batteries? Please email our support team through http://gopro.com/support for further assistance.
http://www.gopro.com/support
May 18, 2010 | GoPro Digital Hero 3 Digital Camera
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
My gopro surf hero won't record.it turns on,everything works except it does not record nor takes photos
Be sure to have fully charged batteries and format your SD card using the FAT format. Start by taking the batteries and SD card out, then reinserting after at least 30 second. Here's an unofficial GoPro user guide and tip sheet that I hope helps. Please only apply the GoPro firmware update to GoPro Hero Wide cameras - not the Hero 3 or standard lens models. If we can answer any questions about GoPro products our contact information is at IcePlanter.com
Aug 11, 2009 | GoPro Surf Hero 5170 Digital Camera
Go pro camera video not recording
Mar 28, 2009 | RTO Gopro Hero Wide Angle 5 170 Video...
DVD stops recording after about 30 seconds
If the take up reel is not working properly the slack in tape drive will cause poor recordings and shut downs.
Sep 13, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Tape shows last 5seconds of previous clip before recording next clip
I'm not familiar with your particular model, but many cameras of this type have a "quick review" function that allows you to see what was recorded for the last few seconds to verify that all is well. This is critical in broadcast situations where you only get one shot to get the video. This is a quick way to verify that all is working without having a blank gap in the recording caused by an inaccurate rew/play/stop/rec sequence.
Check the manual for this "review" function.
Dan
Aug 18, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
GoPro Digital Hero 3 Digital Camera Logo
1,052 people viewed this question
Top GoPro Cameras Experts
David Steeves
David Steeves
Level 1 Expert
abdul rauf
abdul rauf
Are you a GoPro Camera Expert? Answer questions, earn points and help others
