Question about SkyScan 86709 Atomic Wall Clock
Ho do I get the clock to show the seconds instead of the temperature?
Stove clok is not showing time
try pressing the clock button after setting the clock .^-^
Mar 09, 2015 | Kenmore Kitchen Ranges
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
Ho una fotocopiatrice Ricoh Aficio 1113, cpmare sul display SC546. Come posso risolverlo? Vi ringrazio in anticipo
SC546 - Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause:
• Thermistor defective
• Power supply unit defective
May 27, 2011 | Ricoh Aficio 150 Copier
The display is flashing HO, what does this mean?
I was wondering the same thing. This is what I found:
The display shows "HO" or "Hd." What does this mean?
HO" or "Hd" means the dishwasher's cycle time is being extended while it is heating water. At certain points in the wash cycle, the dishwasher uses hotter water to ensure a clean load of dishes. If it detects that the water is not hot enough, it will heat it.
If you're seeing "HO" or "Hd" frequently, check the temperature of the water available to your dishwasher. It's best to do this at the sink closest to it, allowing the hot water to run until it reaches its maximum temperature before you test it with a thermometer. For best results, water should be not less than 120°F.
Nov 08, 2010 | Amana ADB1600AW Builtin Dishwasher
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
How do I set the temperature from centigrade to farenheit on the Eddie Bauer Traveling World clock?
its very easy, actually.
all you have to do is this:
while being in the regular clock mode, just press the DOWN arrow.
when you do this, different functions will appear.
when you press it once, you will star seeing, instead of the weather in farenheit, the seconds of the watch going by.
press it again and ou will see the temperature in celsius.
you can keep on pressing it and see that there are 3 modes:
-Temperature in farenheit
-Seconds of the clock
-Temperature in celsius.
Hope this helps you
Jan 01, 2010 | Watches
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Error "HO"
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature.
Thank You Huum
Please remember to leave a solved rating before you sign off!
Dec 20, 2008 | Dishwashers
Setting skyscan to show seconds not day of the week
let tell me how many switches on the clock you have and each name of switches.
please.
Sep 24, 2008 | SkyScan 86709 Atomic Wall Clock
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
SkyScan 86709 Atomic Wall Clock Logo
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
