Question about Toys
Have a double horse 9053 radio controller bad can I buy another controller to use
I would recommend you purchase a new set of TX/RX crystals and swap them out for existing ones before paying for a new transmitter.A replacement controller is available on the DoubleHorse Manufacturers website and dont cost a lot or you could try on ebay, the same control but from a different model DoubleHorse will work but you may have to change the crystal from your Faulty transmitter into the replacement. Hope this helps and good luck getting back in the air.
Posted on Nov 05, 2012
  • 18 Answers
SOURCE: i could not control my rc helicopter
Please describe your problem in more detail. Are you able to get lift? If it isn't doing anything at all then there are two things to consider:
1.) This model is known to show a full charge when in fact the battery is receiving no charge at all. Contact the manufacturer for assistance.
2.) There's a safety feature that won't allow the motor to engage until the gyro is locked. Be sure to power on the remote first then the helicopter.
If you are getting lift but can't keep it steady then you may have a balance bar issue. If you've encountered a crash or two then this is very likely.
You may want to consider joining RCdiscuss.com. They have an extensive network of RC enthusiasts with valuable knowledge and resources.
Posted on Jun 24, 2010
SOURCE: my double horse 9053 volitation hellicopter rc
I have the same problem, did you find out the answer?
Posted on Dec 20, 2010
kirkx
  • 2019 Answers
SOURCE: Double Horse 9053. How do
As you can see in the link image, the blades are held in by a grip set that splits in half to release the blade.
http://www.shopping.com/SYMA-Toys-industrial-Main-Blade-Grip-Set-For-The-Double-Horse-9053-Gyro-Helicopter/info
http://di1-4.shoppingshadow.com/images/pi/95/e1/cd/103904909-260x260-0-0_SYMA+Toys+industrial+Main+Blade+Grip+Set+For+The+D.jpg
Posted on Mar 12, 2011
SOURCE: instruction manual for double horse
i need the owners manual for the " volitation 9053 helicopter "
Posted on Mar 14, 2011
SOURCE: Can someone tell me what might be wrong with my
it might be the controller that is broken. but it might be if he crashed it too much it could be broken. i had the same problem with my heli but i crashed it a couple times and now it does the same as yours hopefully im some help for u
Posted on Dec 09, 2011
Double Horse 9053 Volitation Gyro cuts out
Most likely a fault with the PCB circuit board and needs replacing. Also check the motors and rotors are running freely as this could also cause the PCB to trip off.
Kind regards, julian.
rccontrolfreak.co.uk
Dec 18, 2013 | SYMA Toys industrial 9077 Double Horse...
THE BOTTOM ROTORS DO NOT SPIN
1) test the button for open or faulty. However clean it with contacts cleaner solvent.
2) Resolder any wires from the button by dry join.
3) Tight the wires from rotor and resolder the dry join from rotor and test again.
You must sure that batteries is FULL charged, otherwise put a new ONES HYBRID ALKALINES. VERY IMPORTANT
God bless you
Jan 25, 2013 | Double Horse 9053 Volitation Remote...
My Double Horse 7000 RC boat will not run
myy was working then stoped. Battery was full. I disasemble it and found that the on/off switch stoped working because of the rust (water is getting inside). I manage to make a direct conection solding the black and red wire in this switch. Try it.
Jan 02, 2013 | Double Horse Radio Remote Control RC...
My helicopter 9053 will not connect to my controller
The receiver is not binding to the transmitter. Make sure the batteries are in good shape in transmitter. I'm assuming it's a 2.4GHz radio frequency.
When you are about to fly, turn transmitter on first after 4-5 seconds turn
heli on or plug battery in on heli. In the manual there should be a page describing radio binding. It will describe on what gimbles to move and
in certain sequences to complete the process. When the light on transmitter stops flashing means the binding process is complete.
Hope this helps.
Dec 15, 2011 | xheli 9053 Outdoor Volitation Metal...
Can someone tell me what might be wrong with my son's rc helicopter? It spins on the ground but does not lift off. It is a double horse volitation 9053.
Dec 09, 2011 | Toys
How remove to balance bar of a toy helicopter 9053
Hi
my 9053 runs for 10secs then cut out, but the red light on the board flashes
Mar 14, 2011 | SYMA Toys industrial 9077 Double Horse...
Instruction manual for double horse 9053 helicopter
Dec 20, 2010 | Toys
I could not control my rc helicopter double horse 9053 please help meeee
Jun 24, 2010 | Toys
Toys Logo
379 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
