Do this This problem
is commonly caused by a dirty automatic idle speed control valve and
throttle valve but always run a OBD2 fault code as well as the
cleaning procedure. Buy a can of throttle valve cleaner (do not use
carburetor spray cleaner!) from NAPA or Carquest (made by CRC
chemicals) and spray it into the air intake while the engine is
running, use up about 1/2 the can, engine will try to stall hold the
speed up, shut it down and let it soak for 30 minutes, restart and
blow out the remaining fluid, shut it down and disconnect the
negative battery cable for 5 Min's to reset the base idle control. If
the above cleaning doesn't cure your issues you need to have the
computer controlled automatic idle speed control system diagnosed and
repaired by a dealer or electronic engine control repair shop.
SOURCE: 2002 chevy trailblazer has rough idle
it could be an o2 sensor. it could also just need a tune up
SOURCE: IDLE PROBLEM
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
SOURCE: Rough idle
I had the same exact problem on my 2004 Colorado (3.5L). Cleaned the MAF sensor (with MAF sensor cleaner) and throttle body/plate - cleared it right up.
SOURCE: we have a 2006 chevy cobalt with a rough idle,
That is split year for fuel filters. If you have one then it's in the back by the fuel tank. It will up alittle in the center.
As far as the running rough; is there any codes in it?
SOURCE: 97 chevy pu 305 vortec, had cyl 6 misfire and
thats usually a sign of a vacuum leak, recheck and make sure you don't have any loose hoses, or cut intake seals
Engine stalls cold or RPM
fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
