Question about Bosch Classixx WFL 2066 Front Load Washer
Hi There, We have a Bosch frontloader Maxx Classic - we moved recently and had the stabiliser bars inserted so no problems would be experienced - unfortunately, when installing the washing machine into it's new position we cannot get it to either drain or spin - is there any simple solution to fix this? - I have drained the plug on the bottom right hand side of the unit. Thanks,,,
    President:
  • Bosch Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Check the drain where the washer drains, your plumbing, important. Pl click 'very helpful' for the free help, thnks.
Posted on Jun 16, 2010
Insert sim and sd cards
Hi Toddjreese,
To insert the SIM and SD cards on your device please follow the steps shown in the graphic of this link: How do insert the SIM and MicroSD card into my DROID RAZR MAXX
Regards,
Gaby
Motorola Support
Jun 11, 2014 | Motorola Mobility DROID RAZR Maxx 4G...
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
regards
shaun
May 17, 2012 | Washing Machines
Hi i have a bosch classic maxx washing machine WAE20260AU with probalm E2 what do i do now?
As you said in the question you are washing machine is showing the error code as E2 is nothing but Error signal due to long heating.If you want to get repair means you just need to contact you are nearest service center for service engineer.Thanks for your question.
Jun 20, 2011 | Bosch Washing Machines
How do I wash delicates, which drawer, what soap or detergent, etc., front loader Bosch machine, bought recently, (lost manual).
WAE18060AU im leaving this on this page becuase it is a model number to a maxx classic the look up site is currently down for maintenance ill message you back in about 6 hrs Rick
Jan 15, 2011 | Washing Machines
Bosch maxx 7 sensitive dryer wich stops everytime and shows that there is a problem with the reservoir
Technician just solved that annoying problem. My dryer is few months old and without pump, so condensed water is dripping to tank by gravity. During drying cloth is collected on filter and condenser, but some amount of cloth goes into pipes and canals on the bottom of dryer and clogged non-return valve where tank is inserted. Side panel ha has to be removed, canals and valve cleaned. To prevent problem technician suggested condenser and filter cleaning after every use. Valve can be removed from bottom without removing side panel.
Dec 18, 2010 | Bosch Dryers
We have a bosch maxx it will fill up with water
motor or drive problem this can be a couple different situations depending on if your unit is belt driven which would be a easy fix you have to be able rto take off the upper cover to inspect the motor drive area
Apr 28, 2010 | Washing Machines
No drum action from my Bosch Maxx for Kids
Hi, How old is your maxx? Have you ever experienced this before?
This is quite a common problem and can be sorted quite cheap to. You will need to take the back off depending on which model you have to access the motor! Take the motor off and then we can sort the problem.....
Get back to me....
Mar 07, 2009 | Bosch Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
228 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
