Question about LG 32LG30 32 in. LCD HDTV
No tv output - LG 32LG30 32 in. LCD HDTV
    Top Expert:
  • LG Master
  • 14,553 Answers
Is this a dead set or what?
Posted on Nov 05, 2012
How can I connect some device to my TV?
In order for this to work, there must be INPUTS on the rear of the TV corresponding to the red, white, and yellow OUTPUTS from the device. You have video input so that means the Y output from the device probably is connected correctly. This leaves the two audio outputs: red and white. Connect the red output from the device to the red (right) input of the TV. Likewise, connect the white output from the device to the white (left) input of the TV.
Mar 19, 2016 | Televison & Video
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
How solve in my POLYCOM VSX 6000 showing error "unsupported signal adjust your PC output"
Try using the S-Video output and then try using the VGA output from the VSX 6000 unit. The unit can be fixed to output from either as the first monitor output (you may have the dual monitor option enabled). If this does not work the resolution of the TV might be HD, the output of your VSX 6000 is Standard Definition. You will need a monitor that accepts standard definition. If this does not work, I would reboot your VSX 6000 and try again. David
May 17, 2014 | Polycom VSX 6000 (220022222001) Video...
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
Don't know how to connect to tv
If the TV has audio output available, there will be RCA jacks somewhere for that. The standard colors are red for the right channel and white for the left, and they'll be clearly marked as audio outputs. Not all sets have audio outputs, though, while they usually have audio and video inputs. So if you find RCA jacks on the set be sure to see how they are marked.
If the TV has output jacks, all you need is a cable with the appropriate plugs at each end. The TV needs RCA plugs, while the input connector to the speakers varies by manufacturer. Typically the speakers will use a 1/8-inch stereo jack if they were made to be used with a computer, and RCA jacks if they were meant to be used in a home-theater setting. In TV sets with audio outputs, the output may be fixed and independent of the TV volume, which means you can turn the TV volume down and use just the external speakers. Or the audio output may vary with the TV volume, meaning you'll always need to have the TV volume on as well. Some people find this annoying.
If the TV doesn't have an audio output available, you can't hook the speakers to the TV. What most people do in that case is use the TV as a video display in conjunction with an AV receiver. The audio and video sources connect to the receiver, which in turn drives the speakers and provides a video output to the TV.
Feb 27, 2011 | Durabrand 5.1 Surround Sound Computer...
My older Yamaha receiver has lost volume on the TV output.
if TV outputs are okay.Then simply connect TV into another input on reciver, AUX,TAPE,VIDEO ETC...if problem persist then output from tv is the problem..check settings on tv
Jul 29, 2009 | Yamaha RX-V2400 Receiver
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
HD Outputs
you mean inputs.
Press the TV/VIDEO button on the remote till the TV goes to the input you want.
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
LG 32LG30 32 in. LCD HDTV Logo
13 people viewed this question
Computer Repairing
Computer Repairing
