Question about Refrigerators
Side by side refrigerator water not flowing to icemaker but dispenses water
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 05, 2012
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
  • 1314 Answers
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Posted on Feb 11, 2008
sdmc73
  • 121 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
the module on the icemaker may be bad or the emitter-recever
Posted on Nov 29, 2008
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
If you don't get water at the valve and it has power it is likely clogged. Take it apart and find most likely a part where the rubber has softened and clogged a hole that is supposed to open up when the valve is triggered. On mine it was at the bottom of a little metal pole that the rubber was bad. Clear the clogged hole and replace the bad seal and you should now have water.
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Posted on Apr 15, 2009
Tfx25zr where is water filter
If your model has a filter The water filter cartridge is located in the
upper right-hand corner of the fresh food
compartment, right below the temperature
controls.
The filter cartridge should be replaced
every
six months or earlier if the flow of
water to the water dispenser or icemaker
decreases.
Download User Manuals HERE
Sea Breeze
Older Model
TFX25ZRY
Use and Care Manual for above model(s)
TFX25ZRBAA
Series 25.2 Cu. Ft. Side-By-Side Refrigerator with Dispenser
Quick Specs
Energy Guide
Use and Care Manual
TFX25ZRBWW
Quick Specs
Energy Guide
Use and Care Manual
TFX25ZRBBB
Quick Specs
Use and Care Manual
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
Jun 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water flow to icemaker
First verify the fill tube feeding the IM is not frozen with ice. Then verify the water valve is working and power is applied when the IM cycles, It will be one of these things.
Eric
Oct 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No water comes out of ice and water dispenser. gsh25jsrfss refridge no water is flowing to icemaker or water dispenser.
Either the inlet filter is plugged, or the valve is not opening. You will have to trace the water line to access these.
Jul 06, 2009 | General Electric GSH25JSXSS Stainless...
Water dispenser doesn't work but icemaker works fine
TAKE A HAIR DRIER AND HEAT UP THE RESEVOUR INSIDE OF THE REFFRIGERATOR BY THE OUTLET UNTIL THE WATER STARTS TO FLOW. GOOD LUCK
Jan 11, 2009 | Maytag MFI2568AE Side by Side French Door...
Icemaker not working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jun 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
I cannot get water out of the water dispenser and the icemaker isn't making ice.
is the water freezing up en route? try a full defrost to see. if not a blockage may have occured.
Jun 04, 2007 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
