Question about Maytag Neptune FAV9800AW Top Load Washer
Will not drain with cloths in it - Maytag Neptune FAV9800AW Top Load Washer
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Remove the front panel and check the drain hose from the tub to the pump for blockage. If the pump is not running at all you will need to replace the pump. Here is the pump to order.
Posted on Nov 05, 2012
Did not drain. i replaced drain pump still does not drain
Could it be one of the valves? My LG front loader had problems with one of the electronic valves not opening and closing properly.
Dec 09, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Won't drain properly
Hi Brian ramsden,
So i understand that your washer is not draining properly even after replacing the pump. It drains without clothes but when clothes are in the appliance it will not drain. I suggest that you contact the manufacturer or you local authorized technician for more information and assistance. This way they can get to the root of what is causing your washer to not drain properly.
-Best Regards-
Jan 14, 2014 | Frigidaire FTF530FS Front Load Washer
Washer or dryer is putting holes in my clothes
Try putting less clothes in on a wash. The main problem is caused due to draining. My brother had this problem. Try stop your washing machine before draining and hand drain them over the sink. Best advice I can give on that one sorry
Jun 01, 2013 | Washing Machines
Cloths come out wet after spinn
The water drained out ok? If yes, the timer is telling the motor to reverse and run in the drain spin direction and it is likely ok. If the draining is slow the clothes could come out wet, if the belt is cracked or streatched the clothes could come out wet. If the motor is not running through the entire spin/drain mode the timer could be at fault.
Will Not Spin
• Check for unbalanced load.
• Check for broken or slipping belt.
• Does the house drain system accept water from
machine?
• Check for blocked drain hose.
• Check for binding tub seal.
• Check for partial engagement of brake assembly.
• Check for obstruction between tubs.
• Check for broken impeller on pump.
Jan 02, 2012 | Amana NAV5800A Top Load Washer
Washer does not drain after rinse cycle
Hi
Thanks for using FixYa. Usually water not draining at all is due to the drain line that is clogged and/or because of kinked drain hoses that’s attached to the Drain Pump. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. If you think that this isn't easy to do--and you may need special tools—then you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. Please do rate the solution and revert for further assistance.
Thanks
Rylee
May 08, 2010 | Whirlpool GHW9200L Front Load Washer
Washer is not spinning fast enough clothes are wet at one point i think i put in too much soap and it said draining problem
If this is a HE front load washer. MAke sure your drain hose is not shuved too far down the drain pipe. Water will syphen back into the washer and clothes will be wet. Drain hose should be in drain pipe 8 inches. See you ownwers manual for drain hose recomemdations. Reason why it says drasining problem is because maybe water is sysphening back into washer and pump is taking long to drain and operating too long and washer senses it. So check your drain hose and make sure its not to far down the drain pipe..re adjust if it is and wash your clothes and see if problem persists...hope this helps
Jul 29, 2009 | Dryers
GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Jul 03, 2009 | GE Washing Machines
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont drain water
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
Maytag Neptune FAV9800AW Top Load Washer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
