Question about Pride Mobility Products Jazzy 1170 XL Plus
Jazzy scooter battries are charged but the scooter will not move
After turning on the scooter it beeps the lights flash and the brake is in the down position and the scooter will not move, made sure that it was
not locked
what do i do next
  • Anonymous Apr 01, 2014
    hook up charger and poer light goes on but charging light does not go on what does this mean
It has to be lock which is drive mode in order to work.
Posted on Mar 31, 2009
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
Apr 28, 2016 | Pride Mobility Jazzy 600 Powered...
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
Mar 28, 2016 | Pride Mobility Used Power Chairs Jazzy...
Jazzy wheelchair scooter 1450. Why does it go crazy with flashing (charging lights)?
Hi Emilee,
The lights flashing crazy, may mean you have locked out joystick. to unlock, try first, turn on joystick and push horn button twice right away. if that did not work, try turn on and push lever forward all the way wait until it beeps, then back all the way until it beeps again. that should do it. If not then count how many lights are blinking and how many times it blinks. consult owners manual trouble shooting guide for answer, or call 800-800-8586 Jazzy tech
Mar 12, 2016 | Health & Beauty
Battries fully charged, turn key on and only beeps 5 times. Thats all.
hi Hal, that is a issue around based the brake or connectors to the brake or the micro-switch that is moved when you move the drive , freewheel lever.. ... firstly make sure the scooter is in drive mode and not free-wheel mode ., where the axle comes apart you will see a number of connectors , make sure they are a good fit ...
Update me please...
Regards
Rob
Oct 29, 2015 | Pride Mobility Products GoGo Ultra X...
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
My jazzy pride 614 wont go anywhere when i push the joystick forword a yellow light flashes but its yo hard to see
if it can be pushed then the free wheel locking lever is needing to be put in the locking position
Mar 18, 2013 | Pride Mobility Products Pride Jazzy 614
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Dec 20, 2010 | Pride New Jazzy 600 Power Wheelchair by...
I have an electric mobility scooter 302Le that is fully charged but will not run. The lights and horn all work but the scooter will not move. The led light in the control box flashes five times. Can you...
Barb the flashes indicate a brake problem. Make sure that you aren't in freewheel. Move the freewheel lever located at the rear of your scooter up and down a few times then put it in drive mode and turn the scooter on and see if you still get 5 flashes If so you will have to replace the brake assembly Hope this helps
Oct 20, 2010 | Health & Beauty
Pride Mobility Products Jazzy 1170 XL Plus Logo
641 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
