Have just purchased samsung UA55ES7500 LED tv and Samsung BD-E8500A. how do i connect our old Austar Box to either of these units. it is not obvious to me and Austar/Foxtel are not interested in helping.
  • 579 Answers
SOURCE: Samsung TV flickering
This is an unusual failure of a non obvious part in the power supply putting noise into the circuitry of the TV.
you either need a competant tech to work on it or if you are good at connecting up cabling just swap out all the guts.
call Module Exchange at 972-298-1212
Posted on Jan 01, 2008
  • 5 Answers
SOURCE: wont play blu ray dvds
stay from Sampson
Posted on Feb 03, 2008
  • 336 Answers
SOURCE: need to connect some samsung audio/video components
I'm guessing that you would like all your components to play audio through the HTZ320. In order to get audio from all these components you will need a digital optical cable from the tv optical out to the HTZ320 optical input. And some composit audio cables (red and white) from tv audio out to the HTZ320 aux input. The video and audio from the dish box, bluray, and the vcr are all going to have to go through the tv first and then to the HTZ320. Use HDMI cables to connect the dish box and the bluray to the tv inputs and composit cables (red white and yellow) from the vcr output to the tv input. If you can give the exact model of the tv I can help you sort things out further. I hope this helps you.
Posted on Aug 27, 2009
SOURCE: samsung led tv will not come out of power
Sorry... this is not a solution, but I wanted to speak directly to you and didn't know how else to communicate with you!! OMG!! My t.v. does the exact same thing!! The power issue and the sound going out after it has been on for a while!! Have you called Samsung yet? I hear they have horrible customer service. Maybe if we get enough people with the same problem we can get something done about it!!
Posted on Sep 30, 2009
  • 4 Answers
SOURCE: Samsung LN26A450 LN26A450C1DXZA won't turn on
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Posted on Oct 30, 2009
I have a samsung dvd player that connects to my samsung flat screen tv. Every now and then someone uses the tv and i don't know how they work it but the info button then doesn't work. if i disconnect
Contact the Samsung service centre. It sounds to be a strange fault with Samsung brand TVs. http://electronicshelponline.blogspot.com/
Inform them the problem you faces with the TV. They will surely provide a solution.
Nov 25, 2014 | Samsung Televison & Video
TV has recently began displaying 2 images slightly offset from each other with lines. I absolutely love this tv plz help!
you have a digital problem..ive narrowed it down to 2 boards..the Main Bd..and the Tcon board..here are the purchasing details
http://www.shopjimmy.com/samsung-bn95-00496b-t-con-board.htm
http://www.shopjimmy.com/samsung-bn94-05038b-main-board-for-un40d6000sfxza.htm
looks like the main board is on backorder..id replace that first..its most suspect..lemme know how it goes
Feb 14, 2014 | Samsung Un40d6000sf 40" 1080p Hd Led Lcd...
My samsung bluray wont turn on , but the led where you insert dvd faintly flashes
Try a different power outlet. Is the player connected to the TV correctly and is the TV on the correct input?
Jan 31, 2014 | Samsung Bd-d6500 3d Blu-ray Disc Player...
NEED TO HACK A SAMSUNG BD-E8500A
You maybe able to get a region free code from these WEB sites for your DVD player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Feb 20, 2013 | Samsung Bd-E8500 3D Smart Blu-Ray Disc...
Unlocking region code for samsung bd-e8500a
samsung bd-e8500a is
locking region how you
Unlocking region
Aug 08, 2012 | Samsung Bd-E8500 3D Smart Blu-Ray Disc...
My 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Apr 09, 2010 | Samsung LTM1755 17 in. HD-Ready LCD...
TV on lights keep blinking off and on but tv won't come on
The problem can be caused by either a Bad Main bd or a Bad Power Supply bd. Those two boards are the common failures. Other boards that can cause this are the T-Con bd and the Inverter bds.. To determine if your tv is in or out of warranty you need to look at your tv Purchase Receipt and see what the Purchase date is. Samsung gives you a One Year parts and labor warranty from the date of purchase on your set. You can also call 1-800-Samsung for more assistance.
Jul 05, 2009 | Samsung LN40A550 LCD TV
EVERY MORNING WHEN WE TRUN ON OUR NEW 55IN SAMSUNG LED TV THE SCREEN IS WHITE AND YOU CON JUST SEE AN OUTLINE OF THE PIX, HAVE TO TURN IT OFF WAIT AND TRUN IT ON AGAIN TO GET A PIX,WHAT THE HECK IT THE...
If your tv is in Warranty call 1-800-Samsung for assistance. You get a One Year Warranty from the Date of Purchase. If out of warranty then you might have a bad Main bd or a bad T-Con bd. Also a bad FRC bd.
Jul 03, 2009 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
