Question about Kodak EASYSHARE V1253 Digital Camera
Kodak V1253 makes noises when its lens retracts?
Hello, I need help with my camera. Lately, the camera works fine and everything, but when I zoom in or out with it, when the lens moves, it makes some sort of mechanical noise as if it's struggling to perform the operation even though it still performs it? I don't know what to do, it started earlier when my camera got stuck and I had to forcibly (but not roughly) push back the lens into its place. (I was in line for a book signing and I didn't have time for this.) Please help, it is very annoying, especially when I'd like to record video. Thanks
  • ffxromancexkh Nov 06, 2012
    JUst found out though that when i add pressure to the side of the lens, it quiets down?
    Genius:
  • Kodak Master
  • 1,019 Answers
This is a motor drive problem, it requires repairs soon as possible before any more damage is done.
Posted on Jan 24, 2013
praky16
  • 744 Answers
SOURCE: V1253 Kodak Lens stuck open, will not power on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.
Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Posted on Feb 12, 2009
  • 52 Answers
SOURCE: The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
Posted on May 16, 2009
SOURCE: Clicking noise when camera is on
I know this question is almost a year old, but thought I'd post a solution for those using Google Search to try and solve this problem. In the "menu" simply scroll to the "AF Control (Video)" option and change "Continuous AF" to "Single AF" and that should solve this issue.
Posted on Oct 02, 2009
  • 61 Answers
SOURCE: Kodak V705 displays E45 error
push in da lense, it might work
Posted on Oct 10, 2009
Obertelli
  • 3006 Answers
SOURCE: camera lens is stuck out and wont retract. Camera
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 10, 2010
Kodak v1253 camera turns off when zoom lever is activated
Maybe the lens movement is sticking and causing additional overload for the camera circuits, thus causing it to shut down.
Dec 21, 2013 | Kodak EASYSHARE V1253 Digital Camera
Droppped it about one foot W/ lens out, now lens won't retract and camera turns off as soon as i turn it on. the lens sounds like it wants to retract but doesn't.
The gear is misaligned and will need to take apart to fix. Do not force since this will further produce more problems. Take it to a camera shop to fix. However, you might get charged alot of money, so I recommend getting a new camera -since they're now getting cheap to buy.
Nov 01, 2010 | Kodak EASYSHARE V1253 Digital Camera
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
The lense pushes forward halfway when turned on
Hi!
I'm afraid you will have to give it away for a repair - it sounds like the lens get stuck in the halfway - could be dirt, sand or something in the reductor or the lens are damaged.
I work in a Kodak service center.
Hope this helps!
Tom
Jul 29, 2009 | Kodak EASYSHARE V1253 Digital Camera
Easy share V1253...will not stay on...lens will not telescope
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
Hope this helps you out.
Jul 01, 2009 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed on a kodak v1253
I fixed my v1253 following these steps:
1. Pulled the battery when the lens starts to come out before it could power itself off.
2. Gently pull the telescope out until it clicks.
3. Use a fine tip paint brush to clear debris out of the cracks.
Camera works just fine now.
Jan 30, 2009 | Kodak EASYSHARE V1253 Digital Camera
Turns on then automatically shuts of
FIRST CHARGE YOUR BATTERY OVERNIGHT AND THEN REMOVE YOUR BATTERY FOR ABOUT 10 MINS PUT BATTERY BACK YOU HAVE TO ADJUST THE DATE AND TIME AFTER DATE EVERYTHING WILL BE OK BUT IF YOU ARE USING 9 OR HIGHER MEGAPIXEL YOUR BATTERY WILL BE DRAIN IN THREE TO FOUR HOURS.
Dec 12, 2008 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed will not retract, canon pc1147 zoom
hope this helps.
Aug 16, 2008 | Kodak EASYSHARE V1253 Digital Camera
Lens barrell doesn't retract for zooming out, only for shutting off.
Hello, Sounds like you have a drive motor/gear assembly malfunction,this type of failure is costly to repair.
Best Regards, Russell
Oct 29, 2007 | Kodak EasyShare DX6490 Digital Camera
Kodak EASYSHARE V1253 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
