Kenmore fabric care washing machine FLOODING
During filling water starts to flood out of the "drain in" area of the back of the washer. Lots of water. 30-40 large buckets before I caught it.
It has worked fine up until this point and I have not changed any settings or performed any maintenance. Is something blocking the water from filling the washer and diverting out the "drain in" pipe in the back?
  • skistylie Jan 04, 2009
    No, not in the wall, the back of the machine...The picture below illustrates the "drain in" port the water flows out of. (circled).
    does this help. To my knowledge there has never been anything on or covering the port and it has never leaked water or flooded until now.
    Does anyone know a reason this may be happening?
    yes... I have looked at the line, but don't know why it is pumping water out.
  • 530 Answers
So the water is backing out of your standpie in your wall? If it is flooding from the wall you need a plumber to snake it. that would not be a problem with the washer.
Posted on Jan 04, 2009
  • erica graber Jan 04, 2009
    that would be your drain line to the pump. you can see all the machanics of the washer if you tip the unit back a little and look up. but not all the way flat because that could missalign some things. i usually tip back put my tool bag under it to prop up against the wall you will see the whole line from where it is leaking to the pump
  • erica graber Jan 05, 2009
    ok that is the drain line so yes it is supposed to pump water out of that line. I see that you removed the rest of the drain line that goes into the stand pipe. if the problem that you can see is what is circled then you need a new hose from pump to cabinet.
Why is water automatically draining as it is filling?
There is most likely a leak with water getting into the cabinet of the washer activating the anti flood switch which in turn drains all water out to stop flooding check for damaged door boot
Dec 21, 2014 | Kenmore Washing Machines
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
Wont stop filling up with water
1. if the water is not flooding the floor, then you have a drain hose siphoning problem. raise or loop the drain hose up in the back of the machine higher than the highest water level of the machine.
2. if water is flooding the floor and the only way to stop it is to shut it off at the fawcet then the water valve is bad and needs replacing
Jul 01, 2010 | Whirlpool LSR5232L Top Load Washer
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
JRR
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine continues to drain and will not fill with water
The end of the drain hose is too low or is stuck too far down the house stand pipe and is causing the machine to siphon water out at the same rate which it is filling. If this wasn't the case, it would be flooding the floor
Dec 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Sep 03, 2006 | Kenmore 44102 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
