Question about Xerox WorkCentre PRO 128 Copier
I want service manual xerox workcenter pro 128
  • 208 Answers
SOURCE: Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Posted on Nov 28, 2007
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
  • 19 Answers
SOURCE: Service Manual for the Workcenter 24
Neil,
Below is the link to a website that has the system administrators manual and the User guide I hope this helps:
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WCM24&Xlang=en_US&Xcntry=USA
Posted on Nov 24, 2008
  • 2072 Answers
SOURCE: I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
Posted on May 04, 2009
  • 24 Answers
SOURCE: xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Posted on Oct 25, 2009
Buna ziua, Am o mica problema. Am un echipament Xerox Workcentre 128 Pro, am instalat un sistem de operare Windows 7 pe x64. Problema este ca nu reusesc sa setez imprimanta sa imi scoata fata verso....
In Windows 7 - Duplex printing in Xerox Workcenter 128:
Go to the printer in your printer folder in control panel. Double-click on it then select menu option named "Printer" and click "Properties". Hope it helps you. It worked for me.
Sep 06, 2011 | Xerox WorkCentre Pro 123/128 Printer
Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
Try this link, it goes directly to the 64 bit driver download site.
http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
I have Xerox workcentre pro 128 copier machine and we don't know what the user name and password is. It was reset from default
Service will have to come reset it. If you changed it from the default of login: 11111 and password of x-admin
Sep 02, 2009 | Xerox WorkCentre PRO 128 Copier
May 02, 2009 | Xerox Office Equipment & Supplies
I need a vistapatch for Xerox workcenter pro 412
Sorry M8!
There arent any patches for making that model working with Vista, not on Xerox site; http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=WorkCentre_Pro_412&Xlang=en_US&Xcntry=USA#Firmware%20&%20Machine%20Upgrades
And nowere else on the net
Good luck
Nic
Mar 20, 2009 | Office Equipment & Supplies
Xerox workcenter transfer belt error
Yes, if you can get the unit out and replace the bealt. With the right tool and parts....... Just kidding you may be better calling a service person.... you may cause more problems and it will cost even more. I would let them do it and get a warrenty with it.
Aug 22, 2008 | Xerox WorkCentre PRO 128 Copier
Neil,
Aug 01, 2008 | Xerox WorkCentre M-24 Color Copier
2 sided printing problem
What driver did you download? The PS driver is much less capable and I am wondering if thats what you downloaded.
I am using the PCL driver and the selections are 1 sided, 2 sided long edge , 2 sided short edge.
Unless you are runnung CAD, you really should be running a PCL driver.
Maybe I am misunderstand what you are telling me also.
If you have the PCL driver and thats still a problem let me know and I will forward all I can find.
Feb 22, 2008 | Xerox WorkCentre Pro 123/128 Printer
Xerox WorkCentre PRO 128 Copier Logo
76 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
