Question about Bose Acoustimass 15 System
I lost sound on one side of bose stereo system., Seems its the power ouput on the right side speaker, i changed speakers and the right one works when plugged into the left output. How do I open the bose accustimass to check for disconnected wire inside??
  • 3 Answers
First lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
Posted on Jan 08, 2009
Buttons to change time not working
Bose Support - Owner Manuals
worldwide.bose.com/axa/en_au/...manuals/page.html
Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo ... IV ·Wave® SoundTouch music system IV · Acoustic Wave® music system II ... manualsfor home theatre systems and speakers ... manuals for stereo speakers ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
[PDF]The Bose® Wave® Radio Owner's Guide
products.bose.com/pdf/customer.../wrv3_guide.pdf
Bose CorporationThese CAUTION marks are located on the bottom of your Wave radio: ... the user to the presence of important operating and maintenance instructions in this.
Nov 01, 2015 | Bose Wave Radio
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
Need to know what is the easiest way to convert a
It is possible but its going to take some patient custom work. You basically have to remove the entire stereo system out of your 93 Cam and then prewire the 93 to prepare the install of the 5 speaker bose system.
You have to modify the space for the bose speakers from the 96. You have to make sure that when you install the system that the speakers are in-phase meaning that they are not going to sound with the woofers sucking in but pushing out like they have to, to get you best sound, you then have to find a location for your 5 speaker Bose Amplifier eaither under one of your seats if the space is available or somewhere in your hatch area, trunk. Make sure that you use the correct Gauge wires for the power connections, they shouldnt be anymore than 12 Gauge in most cases. Do not try to power the Bose speakers with another amp or you will blow the speakers instantly. I cant tell you how to modify or customize all your work to make this happen, this is something that only I could do if I was present with the vehicle, this is something you have to know how to do or get an installer to do it, the problem is that most stereo shops will not do that type of work, most places will eaither tell you to take a hike or they will throw you an outrageous price to do the job just to scare you away and get rid of you.
Good luck my friend and let me know what happens.
Lex..
May 24, 2010 | Car Audio & Video
Bose Lifestyle 20 system. sound from only two speaker
A lifestyle 20 system is stereo only. Two channels. Left and right.
Jun 04, 2009 | Bose Lifestyle 20 System
I'm trying to hookup the bose cinemate speaker system to an insignia tv, polaroid dvd player and at&t uverse cable box. I get speaker sound when watching cable, but when switching to the dvd, there's no...
how many audio input does your cinemate have? in case you only have one, you need an audio video switcher. a sample picture of what you need is on this link > http://electronicsusa.com/svs14.html find what you need, that is just for you to see what its look like. another thing is check you dvd if it has a line input - meaning it allows you to connect another source into your dvd such as vhs, cd, mp3. for for audio video - you need 3 wires (video/audio left-right), for stereo audio - 2 wires (left/right connection). some dvd player call it as line1 and line2 inputs. if you have it then you should be ok. 3rd approach, a simple audio mixer with minimum 3 inputs and 1 ouput is enough. note: last thing, check your connection interface for connection compatibility if you plan to buy audio video switcher or audio mixer. hope this help. regards, cebuwano
Apr 03, 2009 | Bose Cinemate Digital Home Theater System...
Car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
Feb 16, 2009 | Bose Car Audio & Video
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
No Sound
Id call you local stereo shop. I changed the head unit out in my old acura legend and had the same problem. You need to buy a special harness for the bose. Each speaker had its own amp, so i just rip it off and wired the speaker direct and trashed the amps. Now this was an older car and speakers were almost shot so no biggie. I would not recommend you doing that on and 04. Just call your local stereo shop and they should hook you up.
Feb 13, 2008 | Kenwood DNX7100 Car Video Player
Stereo System Doesn't Make Sound
Tell your son not to play with your stereo.
Sorry that was a bit blunt. The Speakers from a bose system generally run at about 4 ohms of resistance, your sherwood amplier is spitting the dummy because it can't handle that sort of a load. get some proper speakers and make sure that they are connected up properly, and that none of the cables are touching.
Dec 11, 2007 | Bose 901 VI Main / Stereo Speaker
Bose Acoustimass 15 System Logo
300 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
