Question about Sewing Machines
Reverse stitch lever won't work on Janome sl2022
My sewing machine won't reverse stitch.
  • 323 Answers
SOURCE: Pfaff Hobby 1142 Reverse stitch lever twisted doesn't work
Take it back to the Dealer.( He probably has a guarantee on the work he did). Let him show you how it works. If he won't do this then it is definitely time to find a more reputable dealer. If you paid for a repair it should have been repaired.
sewman7
Posted on Jul 01, 2008
SewTechWayne
  • 186 Answers
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
Posted on Jan 30, 2009
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
SOURCE: Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Posted on Oct 07, 2009
My Janome JL250 is stuck in reverse
Probably the reverse mechanism has stuck. Only suggestion may be working the lever manually to see if it frees up. Other than that, it would need service or replacement.
Jul 15, 2016 | Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
I have a Janome Newhome 672. Cleaned and oiled it, works great. But, the decorative stitches will not form correctly. The reverse is not engaging. How can I fix this. Also, the button hole knob h
In most cases Laurie, with decorative stitches selected some machines can't sew in reverse. Your stitch length is too long or too short to make the decorative stitches sew correctly. So many things could be wrong. I'd need more info to get you going again.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Oct 22, 2014 | Janome Sewing Machines
My back stitch wont reverse
Has the machine been unused for a 'long' period of time? Some of the Janome machines did a similar thing - the oil becomes 'sticky'on the mechanism attached to the reverse lever. Can often be fixed by removing the free arm cover and spraying a little Innox (using the supplied straw) in the area where the lever operates. Work it back and forth .... it may come good. It could need tobe dismantled if it wont free up however. Good luck! :)
Apr 12, 2014 | Euro-Pro Stitch Art 8660 Mechanical Sewing...
I have a Janome sewing machine, #423S that I have never used. It is second hand. It sews nicely, but I cannot find the reverse lever on it
The reverse lever should be below the stitch width lever. (It's a wide lever in its own recessed area. just above the level of the extension table.) See page 2 (page 4 of the PDF) available here: http://content.janome.com/documents/File/ManualFile/Inst%20book%20419S%20&%20423S1.pdf .
I hope this helps.
Jan 12, 2013 | Janome Sewing Machines
Sewing machine wont stitch in reverse, needle hitting bobbin feed.
since the needle is hitting the bobbin feed it has to be replaced, if the machine continues to hit the bobbin feed the most likely the machine is out of time & has to be retimed at a sewing machine repair shop
they would also be able to see why the machine won't stitch in reverse
Mar 31, 2012 | Brother XR-65t Mechanical Sewing Machine
My Janome Harmony 1017 won't sew all the zigzag stitches. Stitches 5,7 and 8 bog down after just two or three stitches because the fabric isn't moving through the machine. Any suggestions?
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
Aug 29, 2011 | Janome Harmony 1017 Sewing Machine
I've forgotten how to drop the feed dogs-can you help
There is a little lever on the back of the free arm at the bottom. Push the lever to the right and that will lower the feed dog.
Jan 26, 2011 | Janome Memory Craft 3000
Sewing Machines Logo
90 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
