Question about Kenmore Elite 45986 Front Load Washer
What do i do when it says dl?
What do i do when it says dl or f 11?
  • 530 Answers
Usually when it is clicking when it fails and gives you an f11 error code. This means you have a fauly ccu board. it is a communication error between the computer and the door lock. I am 99% possitive you need a new controller.
Posted on Jan 04, 2009
What might be causing the intermittent F-11 codes on a Kenmore Smartwash front loading washer?
f11 error is communication error.most likely bad solder joints in ccu or mcu.
May 08, 2017 | Kenmore Washing Machines
Tip
INTERMITTENT F-DL AND F-11 CODES
On Whirlpool duets, and the Kenmore HE series starting with the HE3 - HE5.
A common misdiagnosis is to replace the door latch when the user gets an F-DL error, or an F-11 & F-DL intermittently. If the machine shows an F-DL, and you hear a distinct clicking as the board attempts to latch the door just prior to the code appearing, the most common problem here is the door lock relay on the CCU. A good way to confirm is: after pressing start, while the CCU is attemting to latch the door, with the top cover removed, gently tap the top of the CCU with a screwdriver handle (or any blunt object) this will often free the relay. I've seen MANY door latches put in, only to replace the CCU a few days later.
on Dec 04, 2009 | Washing Machines
Were do i get battrrey pack for dl 2700
According the installations instructions for the DL 27, the DL2700 uses five AA-size 1.5 volt alkaline batteries.See Page 11 of the installation instructions:
http://napcosecurity.com/download/DL2700_OI209A.37_PROG.pdf
Apr 20, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
My front load locks and i get a error code fL 11 and dL
u need to change the main board. DL is a door lock error code
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite HE4 has fault code of dl and F?
F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
Dl drive
i myself have had problems with nero 6, i was able to use DL after upgrading to Nero 8, which handles things alot smoothly, and easily. Hope this helps.
Aug 29, 2008 | Computers & Internet
Webcam
no make sure u dl latest java and shockwave and flash player ok and latest yahoo msg or aim whatever uuse and then dl latest webcam driver from site ok then windows update then maby a clean up use ccleaner k
Jan 23, 2008 | HP Pavilion dv6000z Notebook
I HAVE A FAULT CODE F 11 AND DL F
it looks as if your having a communication problem between your central control unit and your motor control unit.check wiring connection between these two components.if wiring is ok then you will have determine which of these components is malfunctioning.you can also remove kick plate and remove service manual located on either side at bottom.this should give you some help.
Jun 18, 2007 | KitchenAid KHWS01PMT Front Load Washer
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Kenmore Elite 45986 Front Load Washer Logo
121 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
