Question about Element Electronics Televison & Video
Cant find power cord for element flx 2610 would any other models from element tvs work?
Will the 19 or 32 inch tv cord work from element
    Top Expert:
  • Element Elec... Master
  • 14,553 Answers
As long as same pin out at end and same shape----all are usually the same but one side goes to hot and other to neutral side inside the set.
Posted on Nov 05, 2012
  • 80 Answers
SOURCE: insignia 15 inch lcd tv cant find replace power cord
part # 485-10144-00
try http://bestbuy.partsearch.com or
https://www.vancebaldwin.com
neither have it but there you go
thanks
scott
Posted on May 30, 2008
SOURCE: Element flx-3210 lcd tv
I have an element lcdtv 32inch. The tv is less than a year old, i was watching the tv and it just shut off. The red light is on, when i go to power it up, the blue light comes on for a second then blinks, and goes back to red. I know its not a brand name tv, but for 600 bucks, it should last for more than 8 months. Anyone have any advice ?
Posted on Oct 31, 2008
SOURCE: Element FLX 3202 no power
This was the same thing that happened to me. When I took it apart and checked the power supply the capacitor (largest on the board) was blown. I called Element Electronics, which turned out to be Polaroid, and they sold me the entire control box assembly for appx $115 with a $100 core deposit to ship my old assembly back. My core deposit was credited back to my account within 2-weeks. BTW, when mine went out I had no power light on at all. Lastly, If you have questions about doing this yourself let me know, while I'm no electrical engineer, I did a ton of research trying to solve the problem.
Posted on Feb 03, 2009
SOURCE: my element 19 inch flx-1910 tv will not power up
Element FLX-1910
Problem: When the TV is turned on a picture appears for a few seconds and then the picture turns off. Audio is still heard.
Solution: Not a simple fix! This TV has 4 small florescent looking bulbs that act like a back light to light the image on the liquid crystal display (LCD). At least one of these bulbs is burned out or broken. The wires powering the broken bulb need to be cut and spiced together. Basically you’re bypassing the bulb and completing the circuit when cutting the wires going to the bulb on each end and splicing them together.
WARNING: This worked for me but no guarantee for anyone who tries it. This is a very involved procedure and involves completely dismantling your television. To be honest I don’t recommend anyone trying to fix it unless you are very technically minded and have a couple of hours to waste carefully tearing apart your TV. If anyone is willing to attempt this repair I am willing answer questions.
Cause of problem: It is my guess that this problem occurs when the TV is left on for extended periods of time. Like leaving the TV on when you fall asleep at night. My TV was left on a lot. I noticed that the plastic was melted and discolored where the bulb had burned out. (This can only be seen internally and is no way visible from the exterior)
Posted on Feb 14, 2009
SOURCE: Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
Posted on May 30, 2009
Element FLX-2610 Red standby LED is lit, but will not turn on
The set will need to be serviced, but sounds like you have a problem with either the power supply or main board.
Oct 23, 2012 | Element Electronics FLX-2610 26 in. LCD...
My lcd element FLX-3711B dont turn on.. I plug the cord cable and only flashing front red light? Whats the problem?
The Element FLX-3711b TV is the same unit as several model of Polaroid and Visco TVs. They are all made by the same company just labeled fr different brands. The flashing power light is a very common problem and is caused by a failure of the power supply board. The capacitors on the board short out and this causes the board to not power up correctly. Here is a link to a repair guide for the Visco TV that is the same as the Element FLX-3711B so the information will be the same for both units. The repair guide shows the parts that will need to be replaced on the power supply board to rebuild it.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
I hope this helps you out.
BuddyMc
Jul 10, 2012 | Televison & Video
Hello, I cannot power on my Element Electronics FLX-2610 26 in. HDTV LCD TV. I turned it off the regular way and the red light is on but I cannot turn it on. Any easy solutions?
Unplug it leave it unplugged for about 10mins. replug it in and turn it on. If that doesnt work. Your going to most likely need to change the fuse for the power current. IF your not sure how to do this find expert repair services near you. It is cheaper to buy a new tv unless you try to do it yourself and end up damaging more
Dec 18, 2010 | Element Electronics FLX-2610 26 in. LCD...
FLX-2610 tv.Has always worked fine. Bought a new desktop todsy & hooked up tv as monitor.Now I can't get it out of standby. Changed batteries in remote but not getting response from on set controls...
Have you tried using the power button on the TV instead of using the remote?
This could be a stress or overheating issue on the TV. Try to power cycle the TV by unplugging the power cord from the wall outlet and leave it disconnected for about 30 minutes, then turn it back on.
If same problem occur, then it's the power supply board that have gone bad. For power supply board problem, It would be best to contact the manufacturer or a repair tech for second opinion.
Good luck and have a great day!
Jan 24, 2010 | Element Electronics FLX-2610 26 in. LCD...
Element FLX-2611B won't turn on. The red light is not lit
Just because fuses are intact does not mean it is not damaged. Sometimes a small spike of power does not blow a fuse but damages Transformer windings Before the fuse! If there are no lights picture or sound think powersupply transformer primary.
Aug 14, 2009 | Element Electronics FLX-2610 26 in. LCD...
No power. Can't get it to turn on.
TAKE OFF THE BACK AFTER U UNPLUG IT ,,CHECK THE FUSE
May 15, 2009 | Element Electronics FLX-2610 26 in. LCD...
Element FLX 3211B has no power after 14 months of use. TV will not power on. Checked th fuse near the power cord and the fuse is good. There is no power going to the TV. Tested the power cord and it is...
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Mar 13, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Televison & Video Logo
47 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
