Question about Dell GX745 Refurbished Desktop PC
Dell PC Desktops not sending signal to the monitor
My dell PC Desktop not sending signal to the monitor
  • 733 Answers
If you dont get a signal to the monitor check these two situations:
1.check if the graphic card is properly inserted(pul it out and then back again)
2.check if the monitor in plug in if yes try to test the monitor maybe it's broken
Posted on Nov 05, 2012
zonkpc
  • 68 Answers
SOURCE: Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
Posted on Dec 16, 2008
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
  • 11 Answers
SOURCE: My Dell Optiplex GX1 will not boot. The Monitor shows no signal.
check whether ur ram is working or not. remove the cpu side door and remove the ram from the ram slot and clean it using a eraser gently and fix again it back and power ur pc on and check it
Posted on Feb 23, 2009
benwabnick
  • 2404 Answers
SOURCE: My monitor says there is no signal from my new Dell Studio
Try reseating the video card in your new computer. Sounds like it may not be seating in the slot properly. Take it out and put it back in with the power off and then hook everything back up and then see if you get video,.
Posted on Mar 14, 2009
sodeep
  • 3267 Answers
SOURCE: Dell OptiPlex GX260 PC Desktop keeps switching its self on !!!!!!
Check the pwer settings on Desktop-properties-screen saver- power options and set it from there. Disable Hibernation......sodeep
Posted on Mar 22, 2009
I have a smallercable tv like hook up on the back of my desktop what are they
John E McMahon,
The port you are describing is an HDMI Connector (black) - Connects to a TV for both 5.1 audio and video Signals
NOTE: When used with a monitor, only the video signal is read.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Dec 15, 2015 | Dell Inspiron 570 Mini Tower Quad Core...
Check all cabling, make sure power is done. Try different cable, try different cable format (for example DVI instead of VGA).
Nov 05, 2012 | Dell Computers & Internet
My dell precision 470 has a loud beep sound for a few seconds when i turn it on and the monitor has no signal any ideas?no signal when i plug the monitor
Please refer to error codes for your system here:
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/advtrbl.htm#wp1058075
May 27, 2012 | Dell Precision 470 PC Desktop
I have dell optiplex 755 desktop with lcd monitor.everything is all right but monitor starts for 2 seconds and then turns off help me to solve this problen
If is possible we need to establish if the monitor is defective or not. Please connect to a different monitor/LCD TVscreen or just unplug the monitors data cable from the back of the computer powered it up and check if is giving you a message on the screen as "No signal detected". It will tell you that the monitor is fine and is a problem with your Dell computer.
Jun 29, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
My computer beeps and doesnt send a signal to the monitor or keyboard. When it does send signal it says entering power save mode on monitor. what do i do to get it to boot?
Sounds like you may have a bad memory module. If you have more then 1 memory module installed in the computer try removing one at a time to see if one is shorting your computer. Make sure the power is OFF when removing memory.
Jan 26, 2011 | Dell Inspiron 518 Desktop Computer
Feb 23, 2009 | Dell OptiPlex GX1 PC Desktop
Power save mode
Yes, you arent getting a signal to your monitor from your video card. Try replacing. If its onboard then the Mainboard may be bad. These machines are known by Dell to go bad and is covered under warranty, provided you still have it.
The message you are getting is coming from the monitor, not the P.C.
Its telling you you it went into power save since its not getting a video signal from the P.C. Check connections as well.
If your using any kind of splitter, remove it and connect monitor directly to P.C. to be sure.
Good luck
Nov 28, 2008 | Dell OptiPlex GX280 PC Desktop
Dell GX745 Refurbished Desktop PC Logo
122 people viewed this question
Alun Cox
