Question about Frigidaire GLTF2940ES Front Load Washer
Filter replacement for frigidaire gltf2940es
I have a Frigidaire GLTF2940ES Front load washer & there is an error code Error 20, which Ive read indicates that the filter could be clogged and the impeller needs to be inspected. Where do I find the filter? and the impeller?
  • Official Brand Answer
  • 4,342 Answers
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Posted on Nov 05, 2012
2 Suggested Answers
SOURCE: error code E10 on frigidaire
I have the same problem.  I'm going to search the frigidaire web sight
Posted on Aug 07, 2008
What is the ef2 error code
Good Afternoon Friend,
I understand you are receiving an EF2 error code on your Frigidaire washer, model# GLTF2940ES. The EF2 code states that too much soap was used. I suggest running a cycle without any soap and any clothes in it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire GLTF2940ES Front Load Washer
What is error code 41
Good Afternoon Donna,
I see that you are wondering what an error code 41 is on your Frigidaire washer, model# GLTF2940ES. Error code 41 means the control board thinks the door switch is open. You will want to make sure the door is closed. Reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker. When you restore power select any cycle and start it. If you are still receiving an error code 41, I suggest contacting your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire GLTF2940ES Front Load Washer
Error codes, we've cleaned out the filter. Do we need to reset the Washer code? and how do we do that? Frigidaire GLTF2940ES
Good Morning Kat, thank you for your question!
First, what error code does your washer displayed? Meanwhile, one of the best ways to determine if your appliance has a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker. It is important to wait roughly ten minutes and then turn on the unit. I ask that you please follow up with a comment on the post, at your convenience, to inform me if the error code does not clear so I may advise you the meaning of the error code and/or possibilities of the issue the unit could be experiencing. Thank you and best of luck!
Sep 22, 2013 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire GLTF2940ES0 displays LOC when i press start
Hello & Welcome to FixYa
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
My Frigidaire washer is reading error code E11..how do I resolve this problem?
E11 = Long Fill Time
Check to see the water valves are opened all the way. Check water hose screens for buildup.
Jan 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
Error code 20 Washer stops, beeps and is still wet. What's up? No error codes chart is found on frigidare website.
Greetings,
you need to go to your pump and clean it out..its probably full of change and hairpins and stuff like that....
Dec 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
77 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
