Question about Archery
Arrow rest won't stay up when nocking arrow
It takes severl times to latch with my thume
5 Suggested Answers
  • 252 Answers
SOURCE: My Avalon trunk won't latch and stay closed. I
If it has a trunk release it sounds to be frozen..Also some close themselves electrically...But I am sure you would know if it is electric or not..If not check for a trunck fuse in the fuse box or the owners manual would be the best...If it is a manual trunk and is stuck or frozen you should be able to move the trunk latch with a big flat prybar...And if it is out of alignment the adjustment is at the striker that is mounted to the lid and not the latch itself....Hope thhis helps......Metalpoet
Posted on Apr 17, 2011
BaronVonNuke
  • 1915 Answers
SOURCE: Unit won't turn on and
click here
This tip I wrote documents what you need to do.
Posted on May 15, 2011
SirOmega
  • 72 Answers
SOURCE: Well when i started my
You need to take apart the PSP to fix the buttons. The rubber under them is misplaced or bunched or missing. To open the PSP, you ARE going to VOID your warranty if you have one. To open it there are 4 screws on the back of the PSP. 3 are easily found and the last one is in the battery compartment under the stick that reads something about if you peel the sticker you will void your warranty. There is the last screw. From there, after all the screws are out, the front of the PSP should pop off and you can clean it and adjust the buttons and fix anything you need. Hope this works for you.
Posted on Sep 04, 2011
perkins48
  • 14405 Answers
SOURCE: Hood latch won't latch when closing
Raise hood,have some one go pull hood latch and you look at latch and see if it releases,if it doesn't then cable may need replacing,I would'nt completely shut hood cause you may not get back open,also check hood latches bolts and latch for something bent or broken.
Posted on Sep 21, 2012
Back door won't close
take a philips screwdriver in between where the latch grabs the part of your car its is a circular area and release the latch at the same time pull down on the screwdriver and it will pull the latch back in the correct position to be able to agai n latch to the cars part of the latch to grab to
Dec 01, 2012 | 1994 Chevrolet Suburban
Drop away rest won't stay up when nocking arrow
is it automatic or is it controled by a string atached to the rest?
Nov 05, 2012 | Quality Archery Design Archery
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
2002 chevy tahoe gas cap door wont stay closed
Hello Matthew, Check the hinge on the door and the retainer latch button inside of the filler neck area. Sometimes they stick and won't pop out back out to keep the fuel door latched properly. You can lube the hinge & latch with WD40 to free it up. I have seen this happen a few times on a Blazer. Hopefully, this is all you need. I hope this information is helpful.
Oct 12, 2011 | 2002 Chevrolet Tahoe
2003 Ford Explorer.....door adjar light won't go off, dome lights stays on unless manually turned off, key in ignation creates a dinging noise.
try spraying the latch mechanism with a spray lubricant and open/close the door many times-the sensor is on the door latch (not the 'button") and it is a common problem on fords as the get older. do both doors, spray heavily, and open/close at least a dozen times or more.
Jul 24, 2011 | 2003 Ford Explorer
GMC Envoy 2004 XUV tailgate won't latch closed. Pressure switch makes latch click but when I go to close it, it does not latch.
Two things happen. One the latch is already latched and therefore it's closed before the gate shut, When you try to close it you might notice that the door don't close all the way. This doe'snt have to be thwe case. the other thing that happens if the lock mechanism is working, You here it click? The latch is stuck as the opener is stuck. You might get lucky and spray the latch with Blaster or other rust buster type penatrant. Theres angles though the opening of the latch . Spray on several angles and repleatly close the door trying to vibrate the Penatrant into the stuck area. Looking at the latch use a screw driver to move the latch and see if you can cycle it though it's positions to see if you can latch and unlatch it with the tool and reopen by pullung the handle ( you may need to try ther inside handle too and even the remote openner if you have one. Ussaaaly you need to push the button twice to open the rear hatch so it may take a few trys and spraying to get it to come loose.. Some vehicals stay closed a long time and stuck is the way to think.. But if the door is used often the linkage inside the door mayh have come off the the latch is closed and the linkage doesn't open the laTCH AND THE THING MANAGED TO GET CLOSED WITHT THE DOOR OPEN.
May 09, 2011 | 2004 GMC Envoy
Arrows seem to dip and rise to the target
the spine of the arrow seems to be off a bit. The spine is the stiffness, check a archery chart for your bow draw weight and suggested arrow spine.
Dec 18, 2009 | Saunders Archery Sport & Outdoor - Others
Archery Logo
118 people viewed this question
Top Archery Experts
pbickwermert
Level 1 Expert
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you an Archery Expert? Answer questions, earn points and help others
