Question about RCA Televison & Video
I need the schematics of control module hv splitter P52926S
    Top Expert:
  • RCA Master
  • 14,553 Answers
This rear projection set does not per say have a control module and if has a high voltage splitter it is up front----follow the large red wire from the flyback to it.
I need the schematics of control module hv splitte - 11_5_2012_8_46_01_pm.jpg
Posted on Nov 05, 2012
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: We are looking for a
The deflectionmodule will be almost impossible to get. However it sounds like you quite possibly only need a flyback 259296 and the HV splitter which are the two most common items to fail. you can get both parts at the following link along with free online tech support so you can repair your set yourself, or they can rebuild your Circuit board. Leave them a email include the model number and what you need.
http://servicemanuals.vstore.ca/
Posted on Jul 13, 2008
I need the schematics of the control module
The model listed is an older set----usually if it HAS the splitter it is up front----but most there is not one as it is part of the high voltage transformer----look on the label on the rear where model number is for a Chassis number, that will tell me instantly if a splitter exists or not PTK-------
Nov 05, 2012 | RCA P52926 52" Rear Projection Television
P52926S need schematics of control module
Its rear projection analog set---knowing what is working or not might be helpful.
Nov 05, 2012 | RCA Televison & Video
I need a part # and source for the H.V. splitter for R40W46-8
try encompass.com they have the schematic on line for this set best I can tell part number is 4410z-a001p
Oct 28, 2009 | Zenith R40W46 40" Rear Projection...
Zenith Z56Z98D8 rear projection......HELP!!!
its called a bleeder assembly www.partsstore.com has a replacement for it 172.00 That could very well cause of the HV modules problems.
Oct 27, 2008 | Televison & Video
I change module 267147r only works for 1 min
Most likely the modules you put in also blew again.
The reason is that there is a fault in another section of the set. For an example, the main power supply may also be defective. If its output voltages are not in spec damage will be done.
Many times when there are failures it is very important also locate the cause of the failure. This type of diagnostics can be involved and will require experience with a solid knowledge of the TV set, the proper test equipment, tools, and the service manuals.
The authorized service center is equiped, and has properly trained technicians that can service your set.
Jerry G.
Sep 05, 2008 | RCA HD56W58 56" TV
I hear a sound like a shortcircuit on backside?
Hello eduquiros,
First of all I think you are hearing a clicking sound right? That noise is due to the HV shutdown circuit activating, indicating that excessive current is being drawn. Now the fact that the TV is on is indicating that the current level is right at the point of shutdown, now I would like to know if you have the schematics for this TV? If so locate the input to the HV trippler and measure the voltage with a HV probe, and compare it to the value on the schematic. In addition you say you have a convergence problem, for that I would say you have to change out your convergence amplifier modules.
Now let's get the the over all issue here: Do you have electronics experience? if so you will need a HV probe, a multimeter, and a pattern generator to solve this problem. If you have these pieces of equipment great, if not you will have to get them. If you do not know what these pieces of equipment are, close the TV up and have a TV repair person come and give you an estimate on the repair costs.
If this were in my shop I would triage the issues you are having,
First find that sound you are hearing (the exact location) and determine if it is a clicking noise or a burning noise (arcing).
Second repair that convergence problem, compare the voltage readings with the schematic
Third repair the HV issue
This should leave you with a working TV.
REMEMBER if you do not have electronics experience, have a TV technician take a look at this set.
I hope this helps
Thank you,
Shuttle83
Jul 15, 2008 | RCA P46921 46" Rear Projection Television
We are looking for a deflection module and hv splitter for model D52w20 by x2 mfg # 2004 serial E334C30BC. Can you help?
Jul 13, 2008 | Televison & Video
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
RCA Scenium HD52W140 smoked
Hello Here is a link to get the schematic for this set: http://www.servicemanuals.net/results.aspx?type=SM&brand=424&model=%20D52W20 Thank you
Sep 24, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
Jul 28, 2007 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
