Question about Casio Parts Cash Register PC Desktop
Machine comes up 0.00000LK doesn't let me do anything.
My partner was doing a weekly z accidently instead of a daily z report then trried to clear and even turned key to off and then unplugged machine to get machine to stop now it comes up with this error code and keyboard doesn't let me do anything just beeps and gives me this code. Thanks Frank
  • 737 Answers
Hi. That doesn't look good. What brand and model is it?
Mark
Posted on Jan 04, 2009
2001 Toyota Prius with 155,000 miles. The engine battery on this had been replaced in late 2010 under warranty. The car has been suddenly losing power almost everyday for a week, with the triangle warning...
code p0441 refers to evaporative emission EVAP system-incorrect flow detected===causes hose connections--intake leak---EVAP canister purge valve
Po144 refers to the same fault and causes
Po446 refers to EVAP system--vent control-circuit malfunction===causes --wiring---EVAP canister purge valve---ECM In all cases codes the canister purge valve gets a mention and then the ECM. I would take it back and ask that the canister purge valve be changed or even ask for a new canister as there are occasions when filling the tank to the filler hole will induce fuel into the canister causing it to malfunction.
Aug 03, 2013 | 2001 Toyota Prius
How do i get manager reading on my er a330
I think you mean your end-of-day money totals:
Turn the key to X1/Z1
Touch the decimal point, then the CA/AT/NS (CAsh, Amount Tendered, No Sale) button - or maybe it's just CA/AT on the -A330.
It will print out a Z reading: the day's sales totals and clear them back to zero, except the Grand Totals at the top of the tape.
If you skip the decimal point it will print an X reading: the same tape, but will not clear the totals, so they can continue building. You can print an X tape several times a day if you're curious about sales, so far, without messing up anything.
I talk about Z totals as a daily total, but they accumulate for as long as you let them, before taking a Z reading. It is only a daily report as long as you take it daily, as most business owners do.
Nov 19, 2012 | Sharp ER-A330 Cash Register
HOW TO DO DAILY REPORT
Turn the key to whichever mode your machine uses for reports, then press whichever button your machine uses to issue the report
Oct 09, 2011 | Casio Parts Cash Register PC Desktop
How do I reset my casio CE-6100. I brought it second hand and need to clear it before I can use it.
If you do that, you will need to setup the dealer (system) programming such as keyboard allocation, machine features and memory allocation. You could just edit the programming to suit your business and save a lot of time. print the Z1 and Z2 reports to clear the totals (the grand total can't be reset but you don't need it if you do daily reports anyway).
If you need any manuals,
Casio CE-6100 operation manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-6100_users_manual.html
Casio CE-6100 dealer programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
Sep 01, 2011 | Casio Parts Cash Register PC Desktop
I need someone to show me how to delete the old memory from used cash register machine .
The grand totals are about the only thing that cannot be reset (they are called non resettable grand totals) so you can just turn them off. turn key to program 3 SUBTOTAL 0822 SUBTOTAL 2000 CASH SUBTOTAL Now turn the key to Z mode and press CASH. The machine will print a daily report. Now press CASH again and you should get a small clear report with nothing on it. now you are ready to go. turn key back to REG mode
Jan 24, 2011 | Casio Parts Cash Register PC Desktop
I work for a school, updating keys on existing TE-2400 registers. Simple setup - 53 items, all same department. Have programmed prices and names but having some issues. They previously had keys set up for...
Whew! Where do I start... Okay, reports.
Daily PLU (item): Turn key to z, type 14 then press CASH (if it isn't a PLU report, try 15 CASH, I'm going from memory). For the periodic report, turn to Z2 and try the same thing. If you haven't been printing these reports, the first one will be big, so ignore the first report.
To clear condiment links, try this: Turn key to program mode 3 SUBTOTAL 0 Now press one of the items that has a condiment link SUBTOTAL
Now turn the key back to REG and try it. If it works, then you can do it to the other PLUs that have condiment links. This method may remove the department link, so if you want to use departments, you may need to link it back to dept 1. See how you get on.
If anyone needs a Casio TE-2200 or TE-2400 manual, c-tech collective have them here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Oct 26, 2010 | Casio Parts Cash Register PC Desktop
I haven't had any trouble following the manual to program and run this machine until today. Now it appears to be adding all the days together...I have used the Z daily function and it just continues to...
This is almost impossible. The first thing to do is make sure you are not accidentally performing an X read instead. Depending upon the brand, the top of the daily report should show 'Z' , 'Z1', or 'ZZ1' If it shows X instead of Z or the total keeps rising every day, then you are not performing a Z (reset). you are printing an X (examine only report). If you still have trouble, let me know the brand and model.
Oct 10, 2010 | Casio Parts Cash Register PC Desktop
Weekly sales reports on Casio TE4500f
Hi.
It depends upon the way it was setup by your dealer.
If you turn the key to Z mode, then press CASH, it should print a daily report. If it has been setup for periodic reports, then you turn to Z2, press 1 then CASH and it should give a weekly report.
Mark
Feb 04, 2009 | Casio Parts Cash Register PC Desktop
After doing the report we rang up the first item in X1
Hi. This sounds like a Casio. You are now doing a PLU seperate report. E01 means you turned the key before finishing. Turn back to X1 and press SUBTOTAL then turn back to REG.
Mark
Dec 21, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
44 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
