Question about RCA Televison & Video
P52926S need schematics of control module - RCA Televison & Video
    Top Expert:
  • RCA Master
  • 14,553 Answers
Its rear projection analog set---knowing what is working or not might be helpful.
Posted on Nov 05, 2012
Where is the body control module located on 2002 cadillac deville
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
What system (S) are you having problems with ?
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Instrument Panel Integration Module (IPM)
The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
The IPM functions include the following:
• 54 volt VF display input
• Ambient light sensor input
• Class 2 communication requiring IPM interaction
• Fog lamp switch inputs
• Front HVAC air delivery controls
• Front HVAC sensor inputs
• Front HVAC temperature controls
• Fuel door and rear compartment lid release switch input
• Hazard switch input
• HUD active control
• Instrument panel lamps dimmer switch input
• Ignition switch headlight control
• Interior lamps switch input
• Key in ignition switch input
• Traction control switch input
• Twilight sentinel delay input
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules.
Jun 19, 2017 | Cadillac Cars & Trucks
What does bmc mean and what is it for on 1 2001 buick lesabre
BCM - body control module a computer that controls functions on your vehicle . A BCM controls light's , power door lock's , anti-theft system control , Remote keyless entry , headlamps . On your vehicle three modules make up the body control system .
• The dash integration module (DIM)
• The instrument panel integration module (IPM)
• The rear integration module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each of the modules are connected to the Class 2 serial data line; many control signals are implemented by Class 2 messages.
The DIM is wired to the class 2 serial data line. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
• Control of headlights and exterior lamps
• Lamps On signal with wiper/washer
• Power moding control over Class 2 serial data line
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the DIM. The PMM receives 4 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
• Accessory voltage
• Ignition 1 voltage
• Ignition 3 voltage
• Off/Run/Crank voltage
The RIM is wired to the class 2 serial data line. The various RIM input and output circuits are described in the corresponding functional areas as indicated on the RIM electrical schematics.
• The ajar switch and tamper switch inputs from the rear compartment lid
• The automatic level control
• The cigar lighter relay control
• The fuel door lock and release control
• The heated seat controls
• The park brake relay control
• The rear compartment lid release controls
• The rear defogger relay control
• The retained accessory power (RAP) relay control
• The reverse lamp relay control
• The various controls for the interior lamps
Mar 21, 2017 | Buick LeSabre Cars & Trucks
Hi randy it is me sean, with the chavy tahoe what you mean by plug in and play ?i am useing a lunch 123 scaner that can work ?i plug in the fuel pump control moudel and no start.
Fuel Pump Flow Control Module Scan Tool Information
Engine Controls Schematics for the 4.8L, 5.3L, 6.0L, 6.2L, or 7.0L engines
or
Engine Controls Schematics for the 6.0L (LFA) engine
Fuel Pump Flow Control Module Replacement for the 4.8L, 5.3L, 6.0L, 6.2L, or 7.0L engines
or
Fuel Pump Flow Control Module Replacement for the 6.0L (LFA) engine
Service Programming System (SPS) after FPCM replacement. From factory info it looks like it does need programming . Which engine does your vehicle have
Feb 14, 2016 | Cars & Trucks
How can i fix my odometer on my 2002 envoy
The IPC calculates the mileage based on the vehicle speed signal circuit from the engine control module (ECM). The odometer will display 'error' if an internal IPC memory failure is detected. The odometer displays either miles or kilometers as requested by the activation of the Personalization button on the steering wheel controls. IPC - instrument panel cluster .
Schematic Reference: Instrument Cluster Schematics
Did you perform the Instrument Cluster Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Instrument Cluster
Turn the ignition ON.
Activate the trip reset button.
Does the odometer display switch between trip and odometer?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Important: Program the replacement instrument panel cluster (IPC).
Replace the IPC. Refer to Instrument Cluster Replacement .
Did you complete the replacement?
Go to Step 4
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Install a scan tool.
Does the scan tool power up?
Go to Step 2
Go to Scan Tool Does Not Power Up in Data Link Communications
  1. Turn the ignition ON, with the engine OFF.
  2. Attempt to establish communication with the following control modules:
Body Control Module (BCM)
Driver Door Module (DDM)
Electronic Brake Traction Control Module (EBTCM)
Inflatable Restraint Diagnostic Module (SDM)
Instrument Panel Cluster (IPC)
Liftgate Module (LGM)
Passenger Door Module (PDM)
Powertrain Control Module (PCM)
Does the scan tool communicate with the control modules listed above?
Go to Step 3
Go to
Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications
Nov 21, 2015 | Cars & Trucks
Transfer case control module
unfortunately, you need a good wiring schematic. It probably is controlled from the computer. It sounds like a relay is stuck on. Some computer shops rebuild the module assembly with a full system scan and replace all related parts that can and will go bad with the module. Businesses that can provide a warranty for the work. You need to find what is giving the module a full power on or a complete ground for a completion of the circuit. You need to understand the flow of electricity and how it works into the module. It might be and outside relay stuck on in the underhood fuse panel.
May 25, 2014 | Oldsmobile Cars & Trucks
I need the schematics of control module hv splitter P52926S
This rear projection set does not per say have a control module and if has a high voltage splitter it is up front----follow the large red wire from the flyback to it.
Nov 05, 2012 | RCA Televison & Video
Need the wiring schematics for a 2001 oldsmobile aurora
There are several computer modules involved in your antitheft and security system.
There is the Driver's door module, the right front door module, the right rear door module, the left rear door module, the dash integration unit, the rear integration unit, the instrument panel cluster, the theft deterrent module, the theft deterrent exciter module, the body control module and the powertrain control module. These are all networked together to form the perimeter security and anti-theft system.
Any problems you may be having with this system should be properly diagnosed. Diagnosis of this system must BEGIN with a complete scan of the onboard computer network so that fault codes can be retrieved. and the computer data checked and verified. This is the only way to correctly determine which part of the system is malfunctioning.
Wiring schematics are not designed to give you the location of these components. They only show the wiring connections that are made between them.
What exactly are you trying to fix?
Jan 19, 2012 | Cars & Trucks
I need a schematic to replace the PCM (Powertrain Control Module)in my 1994 Fodr thunderbird 3.8L V6 without/supercharger ..Is this is Big job for a backyard mechanic and how long should it take, my real...
  1. Easy job and should have no problems here some help
    Disconnect the negative battery cable.
  2. Detach the engine control sensor wiring connector from the ignition control module by pressing down on the locking tab where it is stamped PUSH, and remove the connector.
  3. Remove the ignition module and the module bracket from the front fender apron.
  4. Unfasten the two ignition module retaining screws, then remove the ignition module form the module bracket.
To install:
0900c1528006b5b4.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: The ignition module on 1994-95 vehicles is mounted on the front fender apron
  1. Install the ignition module onto the module bracket. Tighten the retaining screws to 24-33 inch lbs. (2.7-3.7 Nm).
  2. Position the ignition module and bracket assembly onto the front fender apron. Secure with the retaining bolt and tighten to 35-50 inch lbs. (4-5.6 Nm).
  3. Attach the engine control sensor wiring connector to the ignition module.
  4. Connect the negative battery cable.
Nov 19, 2009 | 1994 Ford Thunderbird
94 toyota tercel with no spark
Does it got a distribiter or does is it have a coil pack.I'm thinking an distribiter with 4 spark plug tirminals,I would look into the Ignition Control Module if it has one.I looked at a parts listing for the car and it shows it has one but looked at a Typical Ignition System Schematic and it doesn't show the igniton control module in there.But i would think it is needed to control the spark.I would look into it and see if there is one,if there is i would test it that would be my guess of what's causing no spark.I got a pic of the ignition control module and theTypical Ignition System Schematic for you.
Hope it helps
6h1281.jpgIgnition Control Module
graphic.aspx?mod=reptiff&module_id=1&session_id=%7b5c99313e-132f-495e-97aa-54ddd1158904%7d&image_guid=94i44402&print_bw=0&
Feb 01, 2009 | 1994 Toyota Tercel
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
