Question about Kitchen Ranges
I have to turn a knob to get a clock display. When I turn the knob every light on panel comes on then the clock displays but although the knob is on the range does not get hot.
    Problem Solver:
  • 13 Answers
First of all check your breakers. Some ovens display all characters if you aren't getting a full 240v. When you check it may look like it's not tripped but turn them off and on anyhow (there will be a double breaker). If you don't have a full 240v the burners or oven won't heat up. The other problem is they may have dropped the oven and cracked or joggled a plug to your control panel. Moving companies are insured for this so you need to contact the company and let them know what happened. Usually they will either have it fixed for you or get you a new oven. Good Luck.
Posted on Nov 08, 2012
SOURCE: Frigidaire electric slide in range - clock and stove won't work
Your going to have to replace the control pane.
Posted on Aug 12, 2007
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
frankegd
  • 5 Answers
SOURCE: Our cooktop will not turn on!!
Got the same problem.
Here's a work around: Turn breaker off, second person needs to hold the CANCLE/LOCK button (keep holding it!)
Turn breaker back on and keep holding the button, lock feature may turn on, red lock light stays on, KEEP HOLDING THE BUTTON. At the end you will get a F11 (shorted keypad) warning. It may take up to 20 seconds or more but in my case the red lock light goes off, the dashes disappear and everything is back to normal.
Now here are the bad news. This does not fix the problem (I think it's the EOC). Every time the power goes off the red lock light and dashes will come back. It also may require to people to fix this/work around... but, hey, it doesn't cost anything either...
Posted on Dec 10, 2009
How do I set the clock on my 2003 dodge dakota
  • Turn the Dakota's ignition on. Find the "Time" button on the top part of the radio control panel.
  • Push and hold the "Time" button. After a couple of seconds, you'll notice the hour display starts to blink.
  • Turn the "Tune/Scroll" knob to adjust the hour. When the hour is correct, push the "Tune/Scroll" knob. Now you'll notice the minute display blinks.
  • Turn the "Tune/Scroll" knob to adjust the clock's minute display. Push the "Tune/Scroll" knob to save the changes to the clock.
Jun 06, 2015 | 2003 Dodge Dakota
Knen,ore range model 790.74239310 clock panel light does not display the time
Does it appear momentarily when you press the clock key? If so, then you probably have the "energy-saver" feature turned on. To turn it off (so it "wastes" energy by displaying the clock all the time), press and hold that key. When you first press the key, the clock time will display... (Keep holding that key!) Then in about 7 seconds, the display will go blank.... (Keep holding that key!) Then in about 3 more seconds, the display will come back on. Now you can let go of that key, and the clock time will continue to display.
Oct 13, 2014 | Kenmore Kitchen Ranges
How to set clock i 97 stratus
  • 1Crank the engine or turn the key to the "Acc" notch to turn on the electronics.
  • 2Hold the "Time" button on the radio until the display begins flashing.
  • 3Turn the "Tune" knob right or left to set the hour display. When the appropriate hour is displayed, press the "Tune" knob to confirm.
  • 4Turn the "Tune" knob to adjust the minute display. When you are finished, press the "Tune" knob to save the clock setting.
  • U-Connect Multimedia Radio
    • 5Press the "Power" button on the multimedia system.
    • 6Touch the screen where the clock is displayed to bring up the clock setting menu.
    • 7Touch the hour display. Press the arrows on the screen to adjust the hour display.
    • 8Touch the minute display. Press the arrows to adjust the minute display. Press the button at the bottom labeled "Save."
  • May 22, 2012 | 1997 Dodge Stratus
    How do I set my clock in my 2005 CTS?
    1. Press the TUNE/SEL knob to enter the main menu
    2. Turn the TUNE/SEL knob until set clock appears on the display
    3. Press the TUNE/SEL knob to select set clock
    4. Turn the TUNE/SEL knob to adjust the time
    5. Press the TUNE/SEL knob to update the time.Time updated will appear on the display
    Thank you for using Fixya and good luck.
    Mar 16, 2010 | 2005 Cadillac CTS
    What buttons change time display
    How do I set the clock?
    A5
    There are several methods to set the clock, depending on the model.
    Method 1
    Press and hold the BAND and DISPLAY buttons to display the clock
    Press and hold the BAND and DISPLAY buttons until the time display flashes
    SEARCH left to adjust the hours; right to adjust the minutes
    Press BAND button to store the time
    Method 2
    Same as Method 1, except press DISP to store the time
    Method 3
    Press ADJ
    SEARCH left or right to select clock and press ENT
    SEARCH left or right to select the hour or minute
    Turn rotary knob clockwise or counter-clockwise to set the correct time
    Press enter to store the time
    Press ADJ to return to the previous mode
    Method 4
    Press and hold the BAND and FUNCTION buttons to display the clock
    Press and hold the BAND and FUNCTION buttons until the display flashes
    Search left to adjust hours; right to adjust minutes
    Method 5
    While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
    Press the CLOCK knob to adjust the minutes
    When the CLOCK knob is released for 5 seconds, the hours will flash
    Press the CLOCK knob to adjust the hours
    When the CLOCK knob is released for 5 seconds, the time will be stored
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    A5
    Method 1
    Method 2
    Method 3
    Press ADJ
    Method 4
    Method 5
    go to this web site for any thing about ur stereo
    http://www.clarion.com/us/en/support/faq/Audio/index.html
    Feb 18, 2010 | Clarion Car Audio & Video
    Display goes blank, no heat, no oven
    This I hope will be an easy solution for you. I think you have a circuit breaker tripped or a fuse if you have a fuse panel.. I am guessing you have an old fuse panel. When you have a fuse blown on a 230 volt appliance and you turn a swith on (like your knob) it feeds back to other circuits on the 120 circuits and will make it do crazzzy things, like making lights and clocks work..Regardless if you have fuse or breaker you dont have the 240 volt to run the range..You only have one120 volt leg powering your stove.
    Nov 03, 2008 | GE Kitchen Ranges
    Blue LED display too bright
    TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
    Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
    Clock display on KDC-MP235
    I've found the manual to be inaccurate as far as setting the clock. To display the clock, hold down the right knob, then choose Freq or Clock. Push again to set. Easy.
    To set the clock, push the source button until you're in standby mode. Hold the left knob down (volume ctrl) until menu comes up. Either push the left knob OR move the right up or down (can't remember which) until you see Clk Adj. Push the vol ctrl knob (I think). Then, the knob on the right goes left right for minutes/hours, and up/down for the other. I believe you can push the vol knob then once its set.
    Feb 16, 2008 | Kenwood KDC-MP235 CD Player
    Oven control panel
    Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
    set the oven temperature, set the time(s) and to set up your range. To use the
    touchpad, press the center part of the pad with the flat part of your fingertip. A
    beep will sound to indicate that the selection has been made. Turn the dial to the
    desired setting and press START.
    Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
    Clock time display can be turned off. The default display is on.
    1. Access SELECT FUNCTIONS Menu.
    2. Turn knob clockwise until CLOCK DISPLAY is displayed.
    3. Press START.
    4. Turn knob to select ON or OFF
    5. Press START to accept new selection.
    Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
    2. Turn knob clockwise until RESET DEFAULTS is displayed.
    3. Press START. Display reads SELECT FUNCTIONS.
    Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
    Oven stopped working while cooking a meal
    it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
    Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
    Kitchen Ranges Logo
    124 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
