Question about Mitsubishi VS-50609 50" Rear Projection Television
Problem with color
Recently we've been having problems with the color on our TV. The color and picture are fine when you first turn it on, then about 10-20 minutes into viewing, the picture "loses" it's red color/hue, and the image is then only in greens and blues. The image itself is clear, so it's just a color problem. If you turn the TV off for 30 minutes or so, it will turn back on with full color, but will again lose the red color and go to the green/blue screen after a few minutes. It seems like the length of time that the screen stays in full color is diminishing, so something seems like it's "going out" for lack of a better term. Any ideas would be greatly appreciated! Thanks!
    President:
  • 3,130 Answers
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Posted on Jun 05, 2007
Samsung HLN5065W Color/Power problems
Good day!!!!
Kindly check the power supply board..Look at the capacitors within check the visual condition if it is look like bulged,leak or burnt..
If that so,try to replace it with the same type ratings and value..you can order that parts on local or online..
This is the sample images:
Dec 19, 2011 | Samsung HLN5065W 50" Rear Projection...
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
Have to push power repeatedly to get TV to turn on, b&w picture
the CRT is obviously very old and discontinued ,I would recomend investing in a new set
Jun 11, 2009 | Televison & Video
I have a Samsung HLN437WX DLPTV. The problem that
no if the lamp works fine for hours , could be a signal problem check signal connection and wiring
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Visio 32L color goes bad with ghost images after about 5 minutes.
This sounds like one of the two things that destroys electronics. Heat. You can try this. Place a fan blowing into the vents of the set before you turn on the set. See if the set run longer before the problem occurs.
You may have a marginal part or bad connector/connection.
Feb 14, 2009 | Vizio L32 32 in. LCD HDTV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Mitsubishi VS-50609 50" Rear Projection Television Logo
276 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
