Question about JVC Televison & Video
Jvc tv was one we were watch a show tv shut off and the timer/power light started flashing and clicking
Model AV-36980
    Top Expert:
  • JVC Master
  • 14,553 Answers
Older model but does have one common failure----there is a 1,000 microfared 25-35 volt cap that opens and causes this---only 2 leads that are soldered and a - and a + to denote which goes where.
If you can solder it is worth a gamble--5 dollar part---The part location from memory is C925 or similar.
jvc tv was one we were watch a show  tv shut off   - 11_5_2012_4_21_49_pm.jpgIt will look like this but should be black in color with the 1000 uf and below the voltage rating of 25-35 vdc (volts DC) on it---black band is negative and other side positive.
Posted on Nov 05, 2012
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: dead jvc tv,av-27320
There is most likely the main power supply has several shorted parts in it, depending on how old it is, it might be worth at least an estimate. if you have homeowners insurance, you may want to concider reporting this to them. Good Luck
Posted on Apr 06, 2007
  • 142 Answers
SOURCE: jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Posted on Sep 30, 2008
thedayos
  • 57 Answers
SOURCE: RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Posted on Feb 28, 2009
ginko
  • 19396 Answers
SOURCE: TV will not turn on
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
When I push the power button, the red light flashes and no picture shows up. it just clicks right back off? do you know what causes this?
Go to the following blog address to find detailed instructions on how to fix your TV for around 2 dollars yourself! It really works. I fixed mine this weekend.
Good Luck...Kim
Jan 09, 2010 | JVC AV-36950 TV
AV-36980, c926 blown
Electrolytic "CAN" type caps fail for several reasons. 1. over voltage stress. 2. polarity reversal. 3. over current stress. These three things are caused by other components that have also failed or partially failed either before or after C926. Check the rectifier circuit and or the horizontal deflection circuit which gets it's filtered DC voltage from C926. louie12fix on fixya.
Sep 17, 2009 | JVC AV-36980 36" TV
The power button keeps clicking off and on
My set did the same thing. I found the attached blog while I was looking for answers on this website and it explained how to fix the set myself at home for around 2 bucks!!! I tried it and it worked!
Good Luck...Kim
Aug 30, 2009 | JVC AV-36950 TV
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
Jan 07, 2009 | JVC AV-36950 TV
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
Dec 09, 2008 | JVC AV-36950 TV
Jvc tv av-32d502 timer light is flashing will not turn on
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
