Question about Lenovo Computers & Internet
The icon next to the power button on lenovo keeps flashing
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
May 07, 2014 | Lenovo ThinkPad R61 Notebook
I am Unable to eject the disk tray from the lenovo y510p
hi. two things you can try, first try pushng something like a straightened paper clip into the small hole normally next to cd or dvd open button on front bezel cover, the other thing you can try is when computer running, press start click on my computer, place cursor over cd icon right click mouse button, click eject in drop down menu, if these steps fail cd or dvd might need replacing
Aug 09, 2013 | Lenovo Computers & Internet
Lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
Feb 01, 2012 | Lenovo G550 Notebook
My Lenovo ideapad z565 with Windows 7 does not boot after the Windows logo appears. How can I restore it to it's factory settings by using the onekey recovery (F11)? I already did that but nothing...
For you to perform One Key Recovery, it is done by pressing the OKR button next to power button when the computer is off..(OKR or One key recovery is a very small button usually next/ near the power button that has an inverted U-shaped arrow and usually, some models, the color is orange button)..Select "One key recovery" from the options and next, select "Restore from Initial Back up" after that, you may select "start" to perform OKR..
Just in case OKR button is no longer working, you may ask for the recovery CD's from lenovo to manually install windows.
Jul 04, 2011 | Lenovo IdeaPad Z560 Notebook
Not being booted
TRY THIS TROUBLESHOOTING: -Removed all external devices connected in the computer -Removed the battery and AC Adapter -Press and hold the power button for 20 seconds -Plugged back in the ac adapter and press again the power button to turn it on -Right after pressing the power button to turn it back on, keep on tapping or pressing the F8 button to go to safe mode -If the system is already in safe mode and do system restore from the previous date before the problem occured then just wait for it till it restart the system
(NOTE: If F8 is not working do this next steps) You can only do this troubleshooting if you're ready to loose all your files saved in the hard drive for it will restore back your computer to its factory settings.
-Turn off the unit completely -Press the small button that is next to the power button (button that has an curved arrow icon) -Wait for it then you'll be prompted with 3 options (One Key Anti-Virus, One Key Recovery, System Setup) -Choose One Key Recovery and click Next -You'll be prompted 2 options (Restore from initial backup and restore from users backup) -Choose Restore from Initial Backup then click on Next or Start then just wait for it to finish the process -After the process was done click on reboot and it will ask you to setup your computer for the first time again just like when you first got the computer -If all else fails you might need to call the Lenovo Support to ask for Recovery disc or for service repair for possible hardware problem. Lenovo Support Hotline - 18774536686 then press option 2.
Jul 03, 2011 | Lenovo Y560 - 15.6 - 500GB - Gray Hard...
How do you get the ps3 to pick up the blue tooth head set
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be ‘paired’ so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the “Settings” menu, press X on “Accessory Settings.”
3. Press X on the icon labeled: “Manage Bluetooth® Devices.”
4. Scroll down and press X on the icon labeled: “Register New Device.”
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset’s LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on “Start Scanning.”
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: “Register completed”
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Source: www.madcatz.com/faq
Aug 11, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
My lenovo is locked and cannot access it
You can try to use the One Key Recovery function of the laptop. You can find that button next to the power button and it has a upside down curve arrow. However you need to keep inmind that if you use it it woll be back to its factory state and you mght loose all the files in the laptop. To use it make sure that the laptop is on the press the One Key Recovery Button
Aug 01, 2010 | IBM Lenovo ThinkPad T400 7417 Notebook
Lenovo R61 won't get to login
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Jul 03, 2008 | Lenovo R61 T7300 Notebook
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
