Question about Delfield DEL-SSR3S Spec Line 3 door refrigerator
Delfield three door refrigerator will not get below 40 degrees
5 Suggested Answers
  • 87 Answers
SOURCE: Delfield Refrigerator/Freezer Condensation forming outside door seals
I would expect at the very least a heater circuit around the freezer door. Some of the commercial units also have sprung doors to keep the doors firmly shut which you could check by opening the doors. Door heater circuits are normally very reliable and it would be worth checking the voltage is getting to them, they are also a pain to change out. Hope this helps.
Posted on Aug 26, 2007
SOURCE: Delfield 'New 6000XL 6051 Side by Side Refrigerator
I had a similar situation, unit cooling at about 45 deg, pressures were 10 low, 250 high.
Replaced capillary tubing, now unit cools at or below 38 deg, pressures 30 low, 225 high
Posted on Jul 24, 2009
  • 1250 Answers
SOURCE: The refrigerator has been running since we plugged
I think it needs replacing. In some cases, the thermometer is actually the front of the controller of the unit. This could be why it runs constantly. I would also look at the condenser coils and make sure they are really clean.
let's start there. let me know if I can help further.
Posted on Jun 07, 2010
  • 1250 Answers
SOURCE: Does not hold temperature
start with the basics. Make sure the door closes and seals on all sides. If so, check to see that the condenser coil is clean. On some units, you may have to 'Wash" them out and let dry prior to using. Start here and let me know if I can be of further help.
Posted on Oct 16, 2010
I have a delfield freezer that will not keep temp, it warms up about 1 degree every 1 to 3 minutes, the controller only allows a 3 degree window, and thus the unit has broken 2 compressors! door seals seem...
I have found 1 freezer with the identical issue and never found the answer to the issue. I tried everything I know to do and with no success. The customer ended up replacing the freezer. Sorry, but that's all I can offer.
Mar 04, 2015 | Delfield Refrigerators
Delfield vs bev air, which way would you go for a used 2 door under the counter refrigerator in a concession trailer?
I'm not a big fan of either. I've been involved in the restaurant business my entire adult life and neither one impresses me. If I had to choose, it would be the Delfield but keep in mind that their parts have to come from a Delfield supplier. Bev-Air parts are a little easier to get except for things like door hinges and door gaskets. Sorry that I can't really be much more help than this but this is my opinion based on experiences.
Feb 07, 2011 | Delfield 64'' Refrigerated Sandwich Table...
Does not hold temperature Delfield sandwich/salad 2 drawer unit. Is this a cold holding unit or a refrigeration unit capable of refrigerating 40-60 lbs of lunch meat loafs?
Jul 26, 2010 | Delfield STD4427N Stainless Steel...
Ice on top of compressor
You may have a slow refrigerant leak or too much refrigerant in the system. Contact an appliance service company.
Feb 26, 2010 | Delfield 032-F2FH ColdPro Solid Door Reach...
Temperature display reading 32 degrees on delfield 6000 xl freezer unit. Should be set for 0. door has been opened one time this morning. Where is display box to check troubleshooting codes located on...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 | Delfield Freezer Series 6000XL Remote Half...
What are the high and low side operating pressures of a 4448n-12 delfield refrigerator?
Depending onLoad about 30 to 40 # suction between 150 180 head.
Dec 16, 2009 | Delfield 4448N-12
Jun 14, 2009 | Delfield DEL-SSR3S Spec Line 3 door...
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Aug 07, 2007 | Delfield 032-F2FH ColdPro Solid Door Reach...
Delfield DEL-SSR3S Spec Line 3 door refrigerator Logo
19 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
