Question about Mitsubishi 935D8840 Interface Board for WD-62530
My 62 inch mitsubishi projection tv comes for about a minute then goes out with the lamp light on what is the problem
I HEAR MY LAMP BALLAST MIGHT BE OUT. IS THIS THE PRODUCT I NEED?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I would suspect if when it comes on it is a bit dark it may be the lamp itself---when was last time set was serviced or lamp replaced---by service I mean these sets need to be cleaned out inside from dust or dirt building up in the air channels---this will also shut the set down.
Lamp failure is much more common than the ballast.
Posted on Nov 05, 2012
SOURCE: Need to replace ballast on mitsubishi wd-62526
I replaced my own the part cost $109,it was somewhat time consuming since taking the back panel off was a learn as I went.However I still didn't get the red LED to go off.....TV still would not power up in it's normal fashion.Previously I had 2 lamps burn out,and you definetly could tell they burned out.Since then I have changed the power supply feeding($130) the ballast circuit and I still haven't got the TV to come on without defaulting to the red LED,and taking the chasis apart to do this was a real pain.I have posted a question about my problem recently.Still waiting for a solution.Mitsubishi won't sell a customer any parts........they want you to go to atechnician that works on their product.GOOD LUCK!
Posted on Jan 07, 2009
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Posted on Oct 31, 2009
Testimonial: "no wonder you are an expert, we are nothing without you. huge thanks"
  • 52 Answers
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
Posted on Nov 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Posted on Jan 10, 2010
  • 21 Answers
SOURCE: I have a Mitsubishi WD-52725 projection TV .I
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Posted on Jan 20, 2010
Lamp light is flashing...tv will not come on
Bad lamp or ballast which powers it or you name it in these sets, The lamp and ballast are the places to look first.
Lamp on average has two thousand hour life span which is about two years.
Apr 04, 2012 | Mitsubishi WD-62825 62" Rear Projection...
I thought I had a bad bulb. Took out the old one and it was black and melted looking on the inside. Bought a new bulb and put it in the 61 inch DLP and the lamp light is still blinking yellow. I have no...
The tv have clicking noises sounds too?Yes?The board that call Ballast board it is dead too.This Ballast board only job are to ignite the tv projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Aug 12, 2011 | Mitsubishi WD-62827 62" Television
Replaced lamp, tv worked great for a week, yellow blinking status light, dust cover is secure and the switch is good. tv won't power up
Now the tv projection lamp tries to light up to the tv screen and shutting itself down,u hearing tv make alots of cliking noises to the tv set too?Yes,mean the Ballast board it is also dead,now must replaced the Ballast board too.The Ballast board only job are to ignite the tv projection lamp only.
Aug 09, 2011 | Mitsubishi WD62527 62 in. LCD HDTV
Tv starts to turn on then red light comes on and tv turns off
The red light indicates the lamp has has failed to light. You might just need a new lamp. If replacing the lamp does not solve your problem then the capacitors on PWB-Power need to be replaced or the lamp ballast itself has gone bad.
Dec 25, 2010 | Mitsubishi WD-62525 62" Rear Projection...
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
The Red Lamp light is on.
IF YOU HEAR A CLICKING, ELECTRICAL BUZZING. THIS IS NORMALLY THE BALLAST NOT BEING ABLE TO LIGHT UP YOUR LAMP.
Apr 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I replace the lamp into my mitsubishi 61 inch tv lamp number 915P28010 however the lamp took to the tv. Now when I hit the power button the tv will not come on but u can hear the fans runnin. I had someone...
Question?
is your TV making any strange sounds like clicks or any thing else?
YES? ....making noises is the "Ballast"
http://www.discount-merchant.com/MITSUBISHI-38169103GR-Lamp-Ballast-Driver-p/1137373.htm
if you see half of your tv black or out of shape is the light engine!
http://www.discount-merchant.com/MITSUBISHI-RMD52-939P977A10-Light-Engine-p/1120406.htm
so i think it's going to be the ballast..
let me know i can help you more..
good luck!
Dec 31, 2009 | Televison & Video
Mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Oct 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi 935D8840 Interface Board for WD-62530 Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
