Question about Samsung RS265TDBP Side by Side Refrigerator
Freezer not freezing. Especially on the top shelves. I can somewhat feel air coming out on the lower shelf just above the drawers but on the top shelf I feel nothing. Cleaned the coils and vents checked to make sure the compressor fan was operating and it is. Fridge side seems to be okay. The freezer is definitely the problem side. Looking at the control panel on the back of the fridge there are 2 red LED's that are lit. One says LED1 (this was not lit until I unplugged the unit for about 10-15 mins to let the unit reset and then plugging it back in). The other light that's lit up on the control panel/board is the LMP1 light. I can't seem to find any information of whether or not these are fault lights or normal operation lights. Any help would be more than appreciated.
    Top Expert:
  • Samsung Master
  • 9,472 Answers
Look at the back of the freezer wall to see if there is any ice buildup. You may need to pull the back wall to look also. Post back your findings.
Posted on Nov 05, 2012
  • 4 more comments
  • Chris Leckey Nov 06, 2012
    Richard, Last night I pulled everything out of the freezer and removed the back panel in order to gain access to the fan and the coils. I did notice that the coils were iced over . However, there was no ice around the fan and or in the vents/duct work. The fan moved freely and to be honest the amount of ice while thick in areas wasn't as bad as I expected it to be. I then proceeded to defrost the coil about 95% using an blow dryer. Put everything back together and it seemed to be working again. This morning the temp was where it should be in the freezer. I'm not sure if it has to due with defrosting the coil, or the reset via unplugging or on the control panel but it's working again. What I'd really like to know is if it's a problem with a control panel or the sensor. I'll replace what ever it is just so this doesn't happen again. We lost about $50 in food and we are lucky we didn't lose our supply of ****** milk for the little one. Any idea's of what I need to replace?
  • Richard Roth
    Richard Roth Nov 06, 2012
    Replace the defrost thermostat. This would be the first thing to change since the coils were iced up and it is cheap. Here is the part to order.http://click.linksynergy.com/fs-bin/clic...
    Thank you very much for the info. Ordering it now! Any reason the 1 light on the back of the unit wasn't lit on the large motherboard? The small board's light was lit. But the one that says LED1 on the large board wasn't until I did the reset. Not sure if there's a reason for this or not.
  • Richard Roth
    I'm not sure either. Try the defrost thermostat first and see how it acts. Keep me updated.
  • Chris Leckey Nov 30, 2012
    Richard, It seems to have failed once again with the new part in it. Now there is an error code I can pull up that reads " 24 E ". I can't for the life of me figure this unit out. I can't even find the fault or error codes online. Any idea? Also the LED's in the back of the unit are no longer lit up. Smell a faint electrical smell and the only thing I can think is that possibly both of the circuit boards are shot.
  • Richard Roth
    Richard Roth Dec 01, 2012
    Check the coil on the back of the unit to see if it is good. You can test this with a multi-meter TJMA-DM1. You should see a spike of resistance and a slow drop to zero if it is good. Here is the coil to order in case you find it bad.http://bit.ly/Tygp9b
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
SOURCE: Samsung RS2534 Freezer works but fridge side isn't very cold
replace the sensor and the main board
Posted on Jun 07, 2009
Jenn air side by side, refrigerator side is freezing items at 2 on a 1 to 7 scale, how to I fix it?
Thermostat may be off a little but 1 coldest and 7 warmest? Cheap fix be to adjust thermostat and make sure damper flap isn't stuck open
Oct 24, 2016 | Refrigerators
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Fridge is freezing items on bottom
restrict lower airflow from freezer vents to refrigerator is their a damper air flow control ... try blocking off vent halfway for a day or two next to bottom shelf or drawer how cold is the top shelf of refrigerator refrigerator should never be colder than 37 degrees f"otherwise bad temperature controle or the thermistor
Jan 28, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food freezes on shelf below the deli drawer-amana side by side
look between those shelves
you will see hole that goes straigt through to the freezer , your vent diverter may have become dislodged and freezer air is flooding that shelf space
Oct 06, 2009 | Refrigerators
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Samsung RS265TDBP Side by Side Refrigerator Logo
219 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
