Question about RCA Televison & Video
My picture tube tv is eight years old & now I get a good pcture fore only 20 minutes 'till it goes black
The problem has been getting worse over the last 3 weeks-sound is good but unless I let the thing rest for 1/2 hour I don't get a picture back-& now only lasts 20 minutes
  • Rob Poskrop
    Rob Poskrop Nov 07, 2012
    I didn't take it apart-if I leave it on all the time I don't have a problem- any other suggestions?
    Top Expert:
  • RCA Master
  • 14,553 Answers
I would suspect one of two general things---one if the picture dims out and does not just cut out bad solder connections for the filament in the neck of the tube---a look there with set on will when bad reveal if this is the case.
Bad solder connections somewhere on the main board--this happens with age as the board expands and contracts from heat and then cooling down.
If not a do it yourself person it may not be worth a shop repair on a 8 year old set------
Let me know if need advice.
Posted on Nov 05, 2012
salt56
  • 373 Answers
SOURCE: Sony Trinitron experiences
The screen control inside the set may be on the highvoltage transformer or on the crt socket; either way if you can turn it up just a little clockwise and the picture comes up but doesn't look good you are likely to have a bad tube. Or try tapping lightly on the glass neck and watch the picture as you tap. If it reacts to the tap you have a bad tube. but the turning the screen control is the best test. Turn it the other way the picture goes off immediately. bad tube: too costly if it is available.
Posted on Dec 29, 2007
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
ramon49
  • 111 Answers
SOURCE: Just starte last day - turn on TV, (Sears model)
Bad solder on the mother board, chinese were sleeping, or bad tuner or processor chip due to temperature, Sorry pro help needed...
please rate!
Posted on Jul 11, 2009
pra0099
  • 153 Answers
SOURCE: Samsung TV , black screen
Check for the timer settings if possible reset to default......
Posted on Sep 28, 2009
  • 116 Answers
SOURCE: cannot get good tv signal since ITV and other
The transition from analogue TV broadcasting has been painfull in some areas. the only way to get out of this frustration is to buy yourself a digital set top box . This will convert the digital TV signals to analogue form so that your TV can pick them clearly. In any case ,the trend is to have all analogue transmissions phased out altogether
Posted on Oct 24, 2009
JVC 32", 11 years old. flashes from picture to
after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so in your place contact few TV service engineers & ask them how much they will charge for resoldering joints on mainboard & crt tube's circuit board ......
Sep 05, 2011 | JVC Televison & Video
I have a Sony KV-35S26 manufactured Aug '97. The picture comes ON only occasionally. When it fails to come ON, the standby light blinks continuously. Sometimes, the picture comes ON initially then...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 14yrs old itseems TV TUBE is still in good condition because you have said that whenever display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
May 22, 2011 | Sony KV-35S26 35" TV
I have a Mitsubishi CS-40509 TV. It is over 12 years old. Recently, there is at least a 30 second delay before the tv responds to the remote control/control panel commands. If i turn it on, the green light...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 12yrs old itseems TV TUBE is still in good condition because you have said that when display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
May 22, 2011 | Mitsubishi Televison & Video
Eight year old TV with a lot of miles. TV will turn on but for only about five seconds, then it will shut itself off and won't allow me to turn it back on unless I unplug the power and wait a few minutes,...
Make a fist bang on the tv frame bazel,see if u get a picture flashes?Most of these tv problems for an old CRT-(tv tube) design,tv have cold solders joints alots.If used like years in years out tv in used daily.U have a soldering iron,a roll of solders,can u do basic soldering also? Yes.Take the tv aparts resolder the FBT-the flyback tranformer,that the big black block of plastic with a red wire with a cap hook to a CRT-(tv tube).Also resolders the video board,that the board connect to the CRT-(tv tube) those pins sockets keep the video board and the CRT-(tv tube) together.Tv should be working again,if get these two soldering places parts resolders,FBT-resolders for stable tv high voltage.Video board pins sockets resolders for better joints connections between the video board and the CRT-(tv tube) connections.
Feb 03, 2011 | Sharp 27F543 TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
20 inch wega @1999 Picture comes in and out
Try to finde lose connection/ cold solder joint at board attached at end of picture tube. It seems heater/ filament voltage not being supplied to picture tube after a while and picture goes to black.
Jul 22, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony kv32s42 trinitron color tv blinking
sounds like a bad picture tube. Picture and bright settings cranked up for a good pic? Test/rejuv with a crt tester and/or look at the Ik signal on the crt board. A good tube has 3 small pulses during blanking. The crt cathodes are checked with these pulses, pulses too low and the jungle IC will blank the drive. If the picture fades in and out I would check the filament ckt but that doesn't support the "blinks"
Oct 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Oct 07, 2006 | Toshiba 20AF46 20" TV
Televison & Video Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
