Question about DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater
Delonghi dragon 3 turns itself totally off wen it gets hot, u have to wait for it to cool down before you can turn it back on
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: instruction manual
Here are the instructions: DRAGON HM3
If the model is different , download from:
Select your product, insert model and download instructions here
Posted on Nov 25, 2008
SOURCE: actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: I have a Delonghi Dragon HM3 Oil Filled Radiator,
does it have a reset button? Have you thrown a breaker to that plug in? Does that plug in work? Try plugging something else in and find out it could be as simple as a blown breaker. thats the only things I could think of
Posted on Mar 07, 2011
My delonghi oven is making a ticking noise and with all the switches turned off it's is still heating and rather hot. Won't turn off and cool down
Sounds like an improperly grounded element in the circuit... If an element or wire makes contact with the metal frame and welds itself in place, the electrical current can BYPASS the control and heat uncontrolled- throw the circuit breaker to interrupt the power.
A thorough inspection must be made of the elements and wiring.
Help Me Find My Model Number
Dec 12, 2016 | DeLonghi Ovens
Delonghi dragon 3 not working beep
The appliance beep's to indicate a malfunction. My manual say's to contact the De'Longhi customer service.
May 20, 2014 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Vw jetta starts then dies after about 20 min
fuel pump is probly failin--its gettn hot from age causin it to shut down-wen cool it works again
Apr 08, 2014 | Volkswagen Jetta Cars & Trucks
My delonghi dragon safeheat is cutting off. I have not set the timer to turn it off. Is this a safety shutoff from overheating?
It does have a thermal safety and it very well could be the problem. I looked up this review for you. I hope it is what you were looking for. Roger http://products.howstuffworks.com/delonghi-dragon-oil-filled-radiator-heater-hm25e-review.htm
Apr 06, 2011 | DeLonghi Heating & Cooling
Hi i have a new DeLonghi Dragon 3 heater. The timer seems to work opposite to your instructions - i.e. the instructions indicate that the notches must be pushed to the outer ring to indicate the operating...
This is from the instruction manual online:
To set the heating periods proceed in the following manner:
- Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the
time-clock in a clockwise direction until the number 10 coincides with the reference mark s
on the time-clock. Set the time period during which you wish the appliance to work by
pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes.
At this point sections will be visible corresponding to the working periods.
Set in this way the radiator will function automatically every day during the set period.
(Important: the plug must remain connected to power supply).
- To change the programmed time period, just bring back the black notches to their original
position and set the new working periods required.
- If you wish the appliance to function without programmed working periods push all the notches
towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
Jan 29, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Dragon wont turn on, have checked the fuse
We had the same problem. The on/off switch is likely to be broken inside. We tried to fix it but its likely the pcb is damaged. If you contact Delonghi direct they will help resolve. They sent us a new heater (10yr guarantee)!
Jan 13, 2009 | DeLonghi Dragon 3 0820 / 0820T Oil Filled...
Actual output on settings
1. 900 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Turning off oven.
The fan only comes on in the back of the oven when convecting and Automaticaly turns off when you open the door. The exhaust fan coming from the front stays on for qutie a while, maybe 2 hours or so till the oven cools. I think it is just a function of the oven. A good thing in the winter but uses a bunch of airconditioning in the summer
Oct 23, 2007 | Electrolux ICON 30 in. Double Wall Oven
DeLonghi Dragon 3 1025 / 1025T Oil Filled Radiator Heater Logo
103 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
