Question about Acer Aspire 3680 Laptop
Acer arcade delux
Windows says this programe is no longer working so it closes it down
  • 37 Answers
Did you just install this program? If so you will need to use System Restore to remove it.
Posted on Jan 04, 2009
I have an aspire 5315. Acer Arcade has disappeared and I can't seem to find a way to recover or re-install
Start -> Search -> Acer Arcade -> Start search -> when application is found single left click to highlight it -> right click on highlighted area -> send to -> Desktop (create shortcut) -> double click on new Acer Arcade` desktop icon to test the program.
If the above does not fix the problem:
start -> all programs -> accessories -> system tools -> system restore -> restore my computer to an earlier time -> next -> select a bold date on the calendar to the left and an even in the event schedule to the right that both precede/predate whatever change in settings that caused your application's icon or file directory to change configuration -> restore -> restart computer without interrupting to complete restore process -> look for the lost program in its usual place.
If none of these resolve the problem, then the programs may have accidentally been deleted by yourself or perhaps by another user, without your knowledge.
The following Site has links to download and install your lost application or, alternatively, the deluxe version:
http://komku.blogspot.com/2008/05/download-acer-arcade-deluxe-for-windows.html
Nov 22, 2011 | Acer Aspire 5315 Notebook
I have a acer 5950G and it has acer arcade deluxe on it. it will not allow me to play my music. what do i need to run this program
first try updating the program:
  1. In the Arcade Deluxe program, click Advanced and, next, double-click Live Update.
  2. Click Yes to confirm and, then, Update Arcade to install the update.
normally that should fix the problem if not try to check your sound card as well as your speakers.
Jul 14, 2011 | Acer Computers & Internet
When I startup my laptop it goes straight to Arcade Deluxe how do I get back to windows
Per these pages:
http://www.theacerguy.com/forum/topic/quit-acer-arcade-deluxe
http://www.theacerguy.com/forum/topic/acer-arcade-deluxe-loading-on-startup-cant-get-to-windows
This one even tells you how to disable it in windows start up.
http://www.cybertechhelp.com/forums/showthread.php?t=182345
it says to make sure "HOLD" button is not turned on when shuting laptop down otherwise it will do what yours is doing. They are also talking about going in to safe mode and taking it out of start up. Just read the posts and you might be able to get rid of it. The one i found was towards the bottom.
Good luck.
Nov 07, 2010 | Acer Aspire 6920 Notebook PC
The Acer Arcade Deluxe Webcam is not working, but the Acer Crystal Eye Webcam is still working fine. Please, how can I solve the problem with Arcade Webcam software? I believe it stops working after some...
You can do the following: Start your PC as an administrator > click Start or the Windows ball > Control Panel > Performance and Maintenance > System > Hardware > Device Manager > Scroll down to the device driver you wish to roll back > right-click on it and choose Properties > Click the Driver tab and then click Roll Back Driver. Note: Win7 ball > Control Panel > Device Manager. By rolling back the driver, your Arcade Deluxe Webcam should work like it used to.
Oct 15, 2010 | Acer Aspire 55421462 Notebook
I need the program acer arcade for my pc,
Here is a link to another page that has download links for acer arcade depending on the windows version you have running.
Oct 28, 2009 | Acer Aspire 5315 Notebook
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
How do i operate my acer crystal eye on acer 4710 notebook
I can't verify this, but it's worth a shot:
Go into Acer Arcade or Acer Arcade Deluxe OR go into Windows MediaCenter and then select Acer Arcade. Once in Acer Arcade there should bea program called DV Wizard. Once in DV Wizard select Acer Crystal EyeWebcam and the rest is obvious. Once you are done and click stoprecording, the video that you recorded will be in your Videos folder.
Source
Jan 03, 2009 | Acer Aspire 3610 Notebook
In acer 5920, acer arcade installed, can not be started by hotkey
You configure the keys from the Acer Launch Manager. If you go to Start, All Programs,  Acer System you will find the manual telling you exactly how to configure it.
Dec 10, 2008 | Acer Aspire 5920-6727 Notebook
Where can i download acer arcade or acer arcade deluxe for my notebook
what is it?a support driver?you can download it in acer website by using correct searce engine and by inputing the correct model.
May 19, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
