Question about Pioneer Audio Players & Recorders
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
    Master:
  • 689 Answers
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Posted on Nov 10, 2012
3 Suggested Answers
SOURCE: Stereo CD player/tuner XC-L11 not working at all
Just fixed mine - replaced 35v 47uf electrolytic capacitor in awu7837 module (inside shield case) - this module connects to display unit. see www.circuitsonline.net/forum/view/14478 for more info and diagram Cost - 16 pence from Maplin p/n se47m35 kq68y
Regards, Dave
Posted on Sep 29, 2008
SOURCE: pioneer cd tuner deck model xc-is21t missing lead
go to www.donberg.ie and search for ADE7039 CONNECTING LEAD , order code piac 173
Posted on Oct 14, 2008
Pioneer troubleshooting
Looks like a problem with the indication panel which is a fixed 'all-in-one' unit and probably needs a bit of soldering to rectify a few dry joints! More likely your very friendly repair man down the street will tell you he'll send off for a new unIt which he can replace for you at a 'smaLL' FEE!
Jan 08, 2014 | Audio Players & Recorders
I'm trying to connect my LED samsung tv to my pioneer amp M-L11 using the digital audio output. Can you tell me please if my stereo system should be able to be support my tv so that i am able to h
Pioneer Amp input is analog. if there is a headphones out
( no model for Samsung LED TV) , connect it , not using your
Fisual Digital Opitcal Toslink Cable.
If you really need to use the TV digital out you may need a Digital
to Analog converter , to be connected on Pioneer XC L11 Aux Input .
Optical is Out only for that model.
Sep 26, 2012 | Audio Players & Recorders
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. After consistent attempts to put it on, it works but when put off and...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
The service manual is available for free after you register here...
http://www.hifiengine.com/manuals/pioneer/m-l11.shtml
Mar 24, 2011 | Pioneer Audio Players & Recorders
Got a pioneer deh 2050 mpg car cd player, connected the wiring to the + and - and its not turning on,power is available at the leads.Its a second hand unit, I was told it worked before being removed from...
Well you will find a yellow leads,this must also connect with the positive leads,then you will see it will switch on.This yellow lead is for the memory of the cd player.
Dec 29, 2009 | Pioneer DEH-P2000 CD Player
How to connect a pioneer amplifier to sony cd player in car
easy as matey!
connect RCA leads to the preout in the back of the sony headunit run it down one side of the car into the boot and connect the RCA leads to the amp
You will need to wire in the power earth and remote
Remote lead connects to the BLUE N WHITE wire on back on head unit
Run the power lead and remote down one side of car and the RCA leads down other side which will stop interferance
then just connect the ground and that should be you done
Upfront Audio
May 08, 2009 | Car Audio & Video
Pioneer cd tuner deck model xc-is21t missing lead
Oct 05, 2008 | Audio Players & Recorders
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. Nothing happens after that and the system doesn't work. Could you...
On the first board (where the power enters) there is a tall 3 pronged switch, if you turn the board over and solder a piece of wire to the 2 outside prongs, you will find that the Amp works normally apart from that the display reads Cd closed when in Cd mode.
Aug 28, 2008 | Pioneer Audio Players & Recorders
Regards, Dave
Jun 21, 2008 | Audio Players & Recorders
118 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
