Question about Whirlpool Microwave Ovens
Removing the cover on a Whirlpool Microwave Model MA1170XSS-0
When remodeling I took the oven down and the mounting nut for one of the top screws that holds it to the cabinet fell inside the unit. I'm try to remove the cover to retrieve the nut so I can remount it.
    Top Expert:
  • 14,553 Answers
You may find it has security type bolts that require a special bit, take a good look to see what the bolts that secure the cover look like.
Posted on Nov 05, 2012
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: remove kenmore microwave model 7218815180, 1988 model
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
For some models, manuals are available free if a button shows up to the right of the parts listing.
Otherwise, you will need to order an installation / owner's manual from the parts list.
If it doesn't show up, you can contact support via phone numbers available through that page's links.
Posted on Sep 28, 2008
erpaalai
  • 999 Answers
SOURCE: Part 8169394 oven door replacement came with NO instructions
If you can get to the top screws without pulling the unit down then you can do the job. Sometimes though it goes back together and alignment is simpler if it is on a table and the cabinet is off. I have successfully done it both ways but neither is what I consider easy.
eric
Posted on Jul 16, 2009
SOURCE: whirlpool timemaster microwave removal
What caused the plastic metal rack holders to burn against the metal rack
Posted on Oct 21, 2009
SOURCE: I have a whirlpool cabinet mount microwave model
IS THERE A PLATE HOOKED TO THE WALL IT IS RESTING ON. TRY PUSHING UP THEN OUT. IF THERE IS A CABINET ABOVE IT YOU MAY HAVE TO LOOSEN IT ALSO
Posted on Mar 06, 2010
How to open control panel
Remove the top cover by removing the screws on the sides and back.
Now once the top cover is removed , you can see that the front panel is slide into the front chassis , remove the screws and push the panel slowly, remove all the connection to the board after tagging .
Feb 12, 2013 | Whirlpool GT4185SK Microwave Oven
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Can't take down/unsinstall over range whirlpool microwave
You can download the installation instructions for this model here.
Essentially you'll take it in reverse order.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 28, 2010 | Whirlpool MH7140XF Microwave Oven
Can't remove the oven. took the 2 main screws out
On some of the older micro waves besides the two screws in the cabinet above, they also havetwo screws that you get to by removing the top front cover.
Jan 13, 2010 | GE Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Replace control panel on whirlpool microwave mh1140xmq
There are two screws in the vent cover (grille)that goes across the top remove those and the vent cover and you will see one screw in the top of the control panel remove that one,grab the panel slide it up and pull at the top,it hinges downward toward you and will stay there till you get the wires marked and removed from the board.
Sep 13, 2009 | Whirlpool MH7140XF Microwave Oven
eric
Jul 16, 2009 | Microwave Ovens
Whirlpool timemaster microwave removal
Apr 06, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave installation
I'm a kitchen remodeler, and I've seen this problem with Kenmores (so it probably exists with some other brands too. The ones I have seen have the typical bolts through the top, but there's more. The flat mounting plate on the wall has an protruding piece that fits well into the body of the microwave when the unit is slid into place. It has a threaded hole in the end of the extension, and the sheet metal screw or bolt that goes into this is causing your anguish. To access this, you must remove the top front louvers (maybe some other trim plates as well). You'll eventually find the bolt that unscrews with a horizontal screwdriver. Chris Harrison, Richmond Refacing.
Sep 23, 2007 | Microwave Ovens
Microwave Ovens Logo
122 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
