Question about Maytag Dishwashers
Maytag model MDB7609AWW2 wont work after reset sequence.
Maytag model MDB7609AWW2 wont work even after the reset sequence: Hi Temp Wash, Heated Dry... After the reset, it operates for a short cycle and stops. The cancel button does not work during this sequence. Towards the and of the short cycle, the wash and clean LED's light simultaneously, then switches to dry. I've also cleaned out the lower drain filter. What else can I try? thanks.
4 Suggested Answers
  • 500 Answers
SOURCE: the clean cycle light on our dishwasher is
Hi dchris0218,
Two things you can do:
1) Plug the dishwasher out of the wall while active, leave for 5 min, and plug it in again - This should reset the PC Board.
IF it does not:
2) Press the "Normal wash" & "Heated Dry" button 3 to 5 times alternating each button in that sequence. It will enter diagnostics mode, but can be stopped by pressing the "Cancel" button. This should fix it.
IF it STILL does not help, then:
3) Run the Hot water tap in your kitchen until it is very hot, then only try to use your Dishwasher.
This error is caused by incorrect reading by the Temperature sensing circuits.
I hope this helps
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Aug 19, 2011
MNfisherman
  • 11896 Answers
SOURCE: Here again is my model
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Posted on Oct 06, 2010
Daniel S
  • 4323 Answers
SOURCE: DU1055XTSQ3 only HI-TEMP WASH, SANI RINSE, HEATED
Hi
First make sure that nothing is blocking the drain pump assembly that is located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 30, 2011
How do I reset the code.the lights are lit 4 hour delay, rinse only steam clean.
THIS DISHWASHER WAS RECALLED BY MAYTAG.. You might want to call them to see if it is still covered.
If already repaired you might try:
Normal - heated dry - normal - heated dry. then try to use the machine.
Oct 19, 2015 | Maytag MDB7809AWB - MaytagR JetcleanR Plus...
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Apr 03, 2014 | Kenmore Dishwashers
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds.
Sep 03, 2012 | Kenmore 24 in. 15142 Built-in Dishwasher
My Whirlpool dishwasher washes but does not rinse or dry
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Apr 25, 2017 | Dishwashers
Reset kenmore dishwasher
The most common "reset" key sequences are:
Jun 15, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Dish washer the clean light stays on and the dish washer wont run
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
Mn# is 665.16042402 Green clean light blinks 7 times. Wont go into any functions.
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 09, 2010 | Dishwashers
Clean cycle light is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 22, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
337 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
