Question about Emerson Mw8999rd Microwave Oven
Runs but doesn't heat
    Top Expert:
  • Emerson Master
  • 14,553 Answers
If it has a turntable does it move? Possible diode, inverter board (may have the diode on it or the Magnetron.
If an inexpensive unit it may be cheaper to replace than repair.
Posted on Nov 05, 2012
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Mar 18, 2013 | Microwave Ovens
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Oven is not making etables heat
Mar 07, 2012 | LG Microwave Ovens
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
Runs but doesn't heat replaced two fuses and magnetron still doesn't heat
Here is your free answer in under 10 minutes ...
You have a faulty door safety interlock switch. I wish you would have searched your problem here before you spent all that money on the magnetron. I have answered this question dozens of times here at this site.
When the oven runs but doesn't heat, more often than not it is nothing more than a faulty micro switch in the door latch system. When the switch doesn't work properly, the oven doesn't know the door is closed. If the door isn't closed, the oven will not energize the magnetron. Capacitors and magnetrons are **** and expensive answers but these items are extremely tough. It is the tiny contacts in the micro switch that can not stand the repeated abuse given them when we (read me in that number too) open the oven while it is energized causing a repeated flash across the contacts.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Microwave Ovens
Microwave runs but doesn't heat
HI>An oven is equipped with a heating filament that is called.Magnetron.Now if the motor is working but the unit is not heating .Then MAGNETRON is defective and must be replace.
Jul 22, 2011 | Maytag Microwave Ovens
Emerson Mw8999rd Microwave Oven Logo
245 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
