Question about Heartland Kitchen Ranges
Electric burners wont work
Changed the glass top and the burners worked great for one night, now they wont work.
    Top Expert:
  • Heartland Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 06, 2012
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
  • 338 Answers
SOURCE: Hi, my GE glass top oven has a bridge burner that won't work.
the bridge burner is 99 percent chance that it is blown. turn the power off and take that burner out and see if you can see a break in the burner. then replace.
Posted on Nov 30, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
  • 105 Answers
SOURCE: Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
Posted on Apr 08, 2009
SOURCE: stove quit working
We had the same problem. But it would turn back on after 20 or so minutes. But as soon as it heated back up to 350 it would shut off completely. I called tech support but only got someone in India who I couldn't understand. Then I called a local technician and they charge a grip just to look at it! I finally got sick of it and banged on the control panel. To my surprise it turned right on and has been working ever since :) *This method is not recommended for use on children or animals.*
Posted on Oct 17, 2009
Spectra range. Both large burners diagonal across from each other have stopped working. Is this fixable. Other burners OK.
yes it is is this glass top type ? very easy to work on and get parts for , first thing unplug unit from walll, there are two screws near the front of the oven.to the left and to the right of the oven.near the top front . once you remove the screws lift the top up and support it with something look at all the wires and you will see one that has been burned , the only wire you can use inside of this area is what they call glass wire , so it will take the heat . I am almost positive this is just a burned wire , replace the burned wire with glass wire and you should be all set, keeping in mind move the wires away from the burners this time so it wont happen again
Jul 26, 2011 | General Electric Kitchen Ranges
I have a Jenn Air Electric stovetop with a glass top (Black) model # FCE 30600A One of the burners is nor working. Can I remove that glass top and repl;ace the burner?
Yes you can, at least I removed mine on a Kenmore. Be very careful as the burners are very delicate and even more so after they have aged.Look under the edge at the front for 3 screws. The top should pull out slightly and lift.
Apr 11, 2010 | Kitchen Ranges
Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Jan 20, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Burners not comming on
Remove the grill and slide out the glass top. Take a close look at them burner. If all look ok then it may be the switches.
Jul 17, 2009 | Whirlpool RF379 Electric Kitchen Range
Element on light won't turn off when stovetop is cool
You have a burner sensor that is stuck in the open position sending the signal that the glass top is hot. This is not a safety concern but if you want the light working properly you will have to replace that sensor. Perhaps you can now call around and tell the various repair people what you need to have changed and they will be able to tell you how much it will cost.
May 12, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
Kenmore glass top range left front large burner out
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Nov 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
104 people viewed this question
Top Heartland Kitchen Ranges Experts
Dan Webster
Dan Webster
Tom Chichester
Are you a Heartland Kitchen Range Expert? Answer questions, earn points and help others
