Cd jam in panasonic sa-pm17
Cds were jammed in panasonic sa-pm17. I pulled them out with needlenose pliers. Now 5 trays won't go back in. The first tray is the worse making a horrible clicking noise. Is there a way to reset everything? Thanks.
  • emmyvalk Feb 02, 2009
    CD jam. Disassembled unit to free sliders.
    Need timing procedure to reset.
Hi. Got the very same problem. At christmas I had loaded two cd's in one of the racks. I used needlenose pliers as well and pulled each of the 5 trays out (well past their runners). Tried to dismantle the unit with the 3 screws on each side, but gave up. When I turn the power off and on and do a cd check the "hello" flashes then nothing, tried cd/change power button and basically everything else. All I can say is go easy on the unit as I was to forceful an now think i've ruined it. I'm gutted as this was a great mini hi-fi and has served me well. Best of luck with ur Panasonic, cheers.
Posted on Jan 22, 2010
Why won't the CD drawer and Cassette door open on my Panasonic SA-PM17 CD Stereo System?
This does happen with CD trays, it's quite common. I can't remember the exact mot common cause, but it's some worn out part, such as a small (plastic) cog wheel. Search on "cd tray won't open" on the internet to find a multitude of reasons, most to do with computer CD trays, but I guess the mechanism is essentially the same. These may also describe ways round the problem.
Some CD players have a small hole on the front near the tray into which poking a straightened out paperclip should enable you to open the tray by a few mm, enough to be able to pull it open in an emergency - but it's awkward to do on a frequent basis.
May 05, 2014 | JVC XL-F254BK 5-Disc CD Changer
Bush Mini System with iPod Dock and 5 CD Trays the 5 cd changer tray is jammed the cds have came out of place and when pressing the eject button nothing happens
my bush mini 5cd ipod system wont stay on fm radio station when i turn it off at mains then back on its on mw this happens every time help
Aug 11, 2013 | Car Audio & Video
DVD changer is jammed on my Panasonic Sa-pt770 Receiver
if you have 2 tiny screw drivers, if not, the tips of a butter knife might be skinny enough, you can try to insert them a wee bit into both sides of the tray and pry outward, carefully of course, and unjam the tray
Mar 09, 2013 | Panasonic Sa-pt770 Receiver Only For...
I start up my panasonic sa-pt660 and it makes a lot of ticking noises and give me a chgr err. I tried restarting it. I also tried switching it to the radio and dvd player from the remote and the console...
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Oct 29, 2010 | Panasonic SC-PT660 Theater System
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Jammed CD tray system
You may have a disk that fell out of tray onto lower mechanism. Be careful when disassembling mechanism as they have timing gears that are positioned to perform certain functions
May 06, 2008 | Audio Players & Recorders
The CD changer for my stereo (SA-PM193)jammed when I was changing from one CD to another. It looked like a CD was crooked, and I pulled it out. Then the tray wouldn't go back, so I pulled each tray except...
The CD loading mechanism needs to be rebuilt. Hopefully when you pulled out the trays, nothing was broken inside. Assuming it only needs to be retimed, you can expect to pay the local labor rate. If you broke any of the gears, the parts souldn't exceed $15 or so. Most of the gears and parts are rugged. Look for a Panasonic authorized service center for the repair.
Blocked dvd tray
The disk inside is most likely jammed. It would be best to take it to a repairman, or you can try to remove it your self.
Jul 14, 2007 | Philips DVDR75 DVD Recorder
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Nov 19, 2006 | Panasonic SC-HT680 System
1,035 people viewed this question
