Question about Singer 7422
Cotton bunching underneath bobbin casing singer 7105
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 69 Answers
SOURCE: bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Posted on Feb 07, 2009
SOURCE: Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Posted on Aug 07, 2009
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
  • 6 Answers
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Sewing bobbin
Found several answers at this site, mostly addressing the tensioner.
Singer Sewing Machine Bobbin thread is bunching up Yahoo Answers
Jan 14, 2015 | Singer Sewing Machines
Bobbin thread bunching on singer sewing machine...have changed needle and tensions! Help
Try a ball point 11/70 or stretch 11/70 needle. Also rethread the entire machine. Make sure the needle is inserted correctly in the sewing machine. I had this same thing happen to me recently and I found I had the needle backwards.
Aug 06, 2014 | Singer Featherweight 221 Bobbin Case,...
My singer 7470 i start to sew and clicks and bunches the cotton then the bobbin catches on the hook
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
if these suggestion don't help then the machine needs to be checked to see if it needs some type of adjustments
Mar 19, 2014 | Singer 7470 Computerized Sewing Machine
Why when i sew the bobbin thread is loose underneath and jams everything
The cotton is wrapping around bobbin case please help?
Dec 31, 2013 | Singer 7422
My Singer Curvy sewing machine tension is not working. No matter what setting I set the dial to the tension never changes. There is none. My machines stitches look ok on top of the fabric, but bunch up...
try a new needle
make sure the bobbin is turned the right way in the bobbin case
rethread the machine top and bobbin
if these suggestions don't help, then the machine needs to be checked
Oct 20, 2013 | Singer Curvy 8770 Electronic Sewing...
When sewing too much thread bunches up underneath fabric
make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted correctly in the bobbin case
also make sure the bobbin is turned the right way in the bobbin
case also
clean under the needle plate and in the bobbin area for lint
Oct 29, 2012 | Singer Sewing Machines
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
Sewing problems on Singer 132 featherweight
Your top tension must be set on 5 or there is some cotton/fluff stuck in your top tension unit or you have no tension on your bobbin case
Oct 04, 2009 | Singer Featherweight II 117
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Singer 7422 Logo
226 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
