Try to turn off the camera for 5 minutes and when you try to finalize make sure its plug in to a power outlet dont fianlize using just the battery, after 5 minutes power it back on then try it again....
Do you mean Durabrand CD-968
If you do then this CD player will only play NORMAL music CDs (or CD-R CDs). Not MP3 format
This set will not play CD-RW encoded discs.
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say disc error.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get
By so doing your player would play all DVD's with no problem at all.
To resolve this issue, try one or all of the following:
The
Wave® music system is designed to play commercial CDs, CD-Rs,
MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs,
make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
The system may not be able to play certain CD-RW discs. Playability
is dependant on how the disc was recorded, including the format it was
recorded in and the actual disc used for recording. Note: iTunes
defaults to AAC as the encoding format. In order to use iTunes to make
CDs that will play on the Wave® music system, you’ll need to change the
format to MP3 How to Choose Import Options
Different brands of CD-Rs and CD-RWs use different materials which
may affect the ability of a player to read them. If you are burning
your own CD-Rs or CD-RWs, experiment with different brands of discs
If a commercial disc won’t play, check for scratches, fingerprints
or other physical damage. Try the CD in another player. If it still
won’t play, there may be a problem with the disc
Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Has your machine ever played CDs? There could be a problem with the maximum speed you are making your CDs with. Try a much slower speed. Just because the discs say they can be burned at such and such a speed does not mean that that's the optimum speed for your computer...accordianman
