Question about Magellan Maestro 5310 Car GPS Receiver
I wanted to erase all the maps so i gave a format and everything erase. what could i do?
When i turn it on the screen stay blue
    Top Expert:
  • 14,553 Answers
Best suggestion is contact Magellan about this.....
Posted on Nov 05, 2012
Hi, i gave the same problem of the cam' asking me (on the blue screen) to either turn the cam' off or format the card, (which will erase al the pic's and i dont want it to happen) on the other hand, i...
you should be able to go through the card manufacturer and get "recovery software" that will help you get the pictures back off the card. It is likely that the card has gone bad.
Mar 14, 2017 | Olympus i:robe IR-500 Digital Camera
All I can get when I turn on the system in the beginning blue screen, but will not go to the navigational screen
Do not panic when you have your gps receiver stuck on the navigational screen, the problem simply is that the file supporting the loading of the maps and other start up programs might have been corrupted or missing somehow.
The first way to solve this problem is for you to reset the gps receiver, by holding down the reset button or holding down the power on/off button for about 15 seconds, it will restart the gps receiver. This time it should come on to the complete navigational screen,
If it does not, the next solution is for you to format the gps receiver by connecting it to a computer and transferring your maps to the computer, then you format it from the computer, after formating, go to the website and restore your operating system or upload the latest software for your gps from there, then you update your maps and copy back your maps into the gps receiver back.
That should do the job for you. I hope this information helped.
Dec 23, 2010 | Amcor 4800 GPS Receiver
After upoloading maps on my garmin when I unplug the charger my maps go away and I only have audio support
It's a software problem with your NUVI . It can be solved by resetting it .
To reset your NUVI please follow these steps :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 15, 2010 | Garmin nuvi 780 GPS
Formatted on WINxp
You may be in luck
go to this webpage and download webupdater
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
keep your fingers crossed. basically that is an external hard drive... when you format it.. you erase everything... apparently that has partitions in it as you didn't lose everything tho i suspect you did lose the maps
Robert
Jan 08, 2009 | Garmin n?vi 265WT Car GPS Receiver
I have a ique 3600 and was working fine until I plugged in the ac adapter to the bottom of the unit. It won't turn on. I did a soft reset and now I get a flashing Palm Software screen. I even tried a reset...
Mine has gone into the looping/flashing Palm Screen and then displays the hard reset do you want to erase everything. I fixed it by pushing the up button when it gave me the chance to delete everything and it fixed it.
Dec 20, 2008 | Garmin iQue 3600 GPS Receiver
Can't record anything new
You can either use the "Digital Voice Manager" (loaded from the recorder when you first plugged it into a USB Port... OR, when you brought up the files in the recorder, clicked on the folder with setup). Or, if you just want to clean out everything from all four (A-B-C-D) folders, you can format the chip. Turn the recorder "on", press and hold "erase" until it flashes, press and hold "record" until it flashes "format", and press and hold "erase". "WAIT" will show on the screen until the chip is formatted, and you now have a clean chip - 128 meg or thereabouts.
Oct 25, 2008 | RCA RP5010 Digital Voice Recorder
E280 FR0ZEN
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 26, 2008 | SanDisk Sansa E280 MP3 Player
Folder not available
Go ahead and do this, in case the DB is corrupted:
Mar 21, 2008 | SanDisk Sansa e250 MP3 Player
Screen stays black at power up
No decent repair service
or
-Tha Mp3 Doctor
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
Maps and POI's are gone
You can try a Master Reset, but be aware, this will ERASE ALL OF YOUR FAVORITES. To do a master reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but continue to press the screen until the unit asks if you are sure you want to reset. Press yes. This MAY help.
Oct 12, 2007 | Garmin StreetPilot C330 GPS Receiver
Magellan Maestro 5310 Car GPS Receiver Logo
44 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
