Question about Buffalo Technology Buffalo MiniStation Plus hard drive - 1 TB - USB 3.0
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green light is still on. (on hard drivr of course). wont be showen in 'computer' and neither is it showen in disk management. it seems to be broken but why is light still on?
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Posted on Apr 17, 2013
    Top Expert:
  • 9,472 Answers
The light is for power to the drive.
Posted on Nov 06, 2012
3 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: remove all programs and encryptsion software from buffalo minista
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
BUT the section that may be of interest to you is just after step 5.
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
  • 10406 Answers
SOURCE: my usb external Buffalo ministation
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
How to access my Buffalo HD-PNTU3 external hard drive?
dropping it while turned on is fatal as it usually damages the write heads and/or the platters.
if it hit the floor, changes are it's physically damaged the mechanism.
recovering data from a drive with this damage is not cheap as you will have to send it away to be rebuilt. It's impossible to rebuild it yourself.
Feb 21, 2016 | Buffalo Technology Buffalo MiniStation...
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
Jul 22, 2013 | Buffalo Technology 320GB MINISTATION TURBO...
I have had my current Buffalo MiniStation Plus HD-PNTU3 for almost about a year now without an issue or problem but recently it refuses to open on another computer while it works fine on my own. I am
The device probably can with a Buffalo utility/driver disk. The other computer will need these drivers to recognize the device. If you lost the driver disk, you can download them here: http://www.buffalotech.com/support-and-downloads
May 31, 2013 | Buffalo Technology Buffalo MiniStation...
Computer wont recognise external hdd
Follow these steps:
1. right click on My Computer
2.Click on manage
3.Click Disc Management
There you can see External hd (you can chose to activate or change drive letters and that will do the job)
Mar 29, 2013 | Buffalo Technology DriveStation HD-HC500U2...
I force ejected my Buffalo Ministation 500 external hard drive and now my computer will not recognize it when it's plugged in. Is there a way to fix it or recover the data on it? There are irrepl
There is a possibility that your hard drive has experienced logical damage due to your hard drive is not visible. In this case to recover your data i would suggest you to use some data recovery software that will get online in both free and paid version.
Mar 01, 2013 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
My usb external Buffalo ministation is not been recognised on my pc and the LED light is flashing green and orange
* USB cable
Nov 04, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
When I connect my buffalo driver the yellow light flashes and I am unable to locate the external drive on my computer.. HELP!!!!
Try to plug your External Drive to other usb port or to other computer, or change the cable.
let me know the result.
dm
Mar 21, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
Can't see my buffalo usb ministation under my computer
right click on my computer click manage, then in the new screen click on disk management, can you see the device there? if so right click on it and click delete partition, then after right click and make a partition and format it with a quick format, this should then show it in mycomputer ,this will delete all data on the hard drive!
Jul 02, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
Buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Oct 18, 2008 | Buffalo Technology 320GB MINISTATION TURBO...
Buffalo Technology Buffalo MiniStation Plus hard drive - 1 TB - USB 3.0 Logo
2,226 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
