Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
F2 and F3 code appearing along with annoying beeping
Kenmore Model #911-41055 591 We were baking something in oven and it started beeping and an F2 code appeared. We pressed clear/cancel and it would stop but then start beeping and giving us code 30 seconds later. We finally had to shut main power off to oven.
Then we turned power back on and now it's giving us an F3 code and beeping. The oven will not turn on at all now. It just beeps with F3 code now. What can we do and what can be wrong with oven?
  • Anonymous Mar 25, 2014
    IS THERE SOMETHING TO CHANGE
  • Anonymous Mar 31, 2014
    the oven not working at all when I press bake
  • 530 Answers
I think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Posted on Jan 04, 2009
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
What does the code f2 and f3 mean?
my ove is in selfcleaning mode and is beeping f2
Feb 16, 2012 | Kenmore 47712 / 47714 / 47719 Electric...
I want to repair wall ove 911 3128812 kenmore
first thing to do is to look it up, do you have the booklet that comes with it can look it up that way. If not you can go on the mfr website and punch up the model # it will tell you what the code refers to. When we know what the problem is we can fix it
Nov 15, 2011 | Ovens
Shortly after pressing the Bake button it starts beeping and F3 shows on screen. In the past, it would do this a couple times and then begin to heat and be fine. Othertimes, it would just stop cooking in...
F3 error code is telling you the oven temperature sensor has failed on the oven. You can access the oven sensor from inside the oven. The sensor is a stainless steel probe about 1/4 inch in diameter and several inches long. Disconnect the power to the oven and remove the screws that secure the probe to the rear oven wall and you can usually pull it into the oven.
Jan 19, 2011 | Kenmore Ovens
I have a Kenmore model #40121. I tried to use it today and after it was on for about 15 minutes at 425 degrees it started beeping and flashing F3. I turned it off and back on and about a minute later it...
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 04, 2010 | Kenmore 40192 / 40199 Electric Single Oven
I'm getting a beeping f3 when I press bake. model is 31806660
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
1,232 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
