Question about Cell Phones
Registration code for blackberry tether app v 1.4.3.7
Registration code
How to tether a blackberry smarthphone?
Usually for tethering it depends on the carrier and if they support that feature .Also it may have an additional cost on you data plan .
hope this helps !!
Dec 11, 2012 | RIM Blackberry Curve 8900 Smartphone
Tip
Use ANdroid phones as Modems when using laptop or desktop(pc).
The process of converting android phones to modem is called Tethering.
Before looking for and purchasing a suitable app, you will need a few things:
Android phone
Android phone drivers for your laptop or PC's operating system
USB cable
You should also be aware that using your mobile as a modem will impact on your data plan, so make sure that tethering your phone won't result in a huge bill from your network. Note also that some networks block tethering, which is why you might need to root your Android.
The first thing you need to do is find a suitable app. Several are available from the Market each with different requirements. Some must be paid for, whereas the free ones will usually require root access.
Four popular Android tethering apps are:
PDANet - costs $10 and doesn't require root access; also requires a desktop app.
EasyTether -this app is also $10 and doesn't require a rooted phone.
Tethering Widget - a free tethering app that requires your Android to be rooted.
Tethering - a free app that doesn't require rooting.
(I personally prefer tethering bcause its free)
Once downloaded and installed, these apps can then be tethered with a USB cable to use your Android cell as a modem for your computer.
HOW TO
Now that you have chosen and installed a suitable app to use your Android phone as a wireless modem, you can take advantage of the functionality it delivers. Once your phone is connected to your PC or laptop you should find that with the app installed and running, and the correct drivers installed on your PC, the computer will detect your phone as a modem and let you access the Internet with it.
There are differences in the various apps at this stage (for instance PDANet employs a client app on your PC) so you will need to check the instructions for the one you choose. The general rule is that with mobile internet active on your phone, your Android connected by USB to your computer and the application running, your PC will now be able to use the phone as a new network connection!
eNJoy !!
on Feb 06, 2011 | Google Android
Tip
How to Wireless Tether mobile internet from HTC Hero to Computer.
Intro :
This quide will help you setup you phone as a wireless router. I tested this on HTC hero A6262( Firmware : 2.1 , Villain 3.1 ROM)
You will need :
1. An android device with root access.
2. Mobile Network Connection
3. Wifi Tether/ aNetShare application in the phone.
Intructions :
1. Enable the mobile network from setting.
2. Open the Wifi Tether/ aNetShare app in your phone, and tap “Start tethering”.
3. Go to PC/Laptop and search for wireless networks, you will see you phone’s SSID.
4. Click connect.
5. Once connected open firefox.
6. Go to Tools > Options > Advanced Tab > Settings.
7. Select Manual proxy configuration and enter the proxy setting.
8. Click Ok.
9. Enjoy !!
on May 23, 2010 | Cell Phones
Blackberry curve 8520 call failed
I think your Blackberry cell phone is locked to a specific network you need to unlock it,You can get unlock code at cheapest rate by BLACKBERRY CURVE 8520 UNLOCK CODE provider.
*Visit BLACKBERRY CURVE 8520 UNLOCK CODE
THANKS ! ! !
Oct 20, 2011 | RIM BlackBerry Curve 8520 Smartphone
How to tether my milestone to my loptop
You can tether your droid to a computer with a USB cable to share internet connection, but verizon charges you a hefty price.
Fortunately, there are apps on the android market that also do the job.
Method 1: Tether Android with Apps that Need Root (Free, heavy configuration)
The Android Wi-Fi Tether application turns your phone into a Wi-Fi hotspot--essentially aMiFi--in one tap. The catch? You have to gain root access to your phone, a multi-step process that uses an unofficial Android add-on which can brick your phone if applied incorrectly. Rooting Android is doable for geeks and hackers with experience soft-modding hardware, but it's not something most users could (or should!) do.
Method 2: Tether Android with Proxoid (Free, no root required, some configuration If you don't want to gain root but know enough to get around the command line and use proxy servers, the Proxoid Android app can tether your phone for free.
Method 3: Tether Android with PdaNet ($30, no root required, minimal configuration Finally, the PdaNet Android application lets you tether Android using an app on the phone plus simple software you install on your computer
Jun 06, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I have HTC smart f3188 how should i connect to it to pc for internet connection.
First try this: 1) While the phone is connected to the computer, go to settings on the phone 2) Select wireless and network settings 3) Select Tethering, you can turn tethering on from there. Most carriers will require you to pay extra for this feature to work. Another option: 1) Go to android market and look for a tethering app. (I.E. PDANet). Some carriers have removed these kinds of apps from the market, so you might not find one. 2) After the app has been installed,it should guide you through the process of setting it up. Some tethering apps will require you to have another program on the computer you are connecting to.
Mar 05, 2011 | HTC F3188 Smartphone
Error 907 invalid cod file.. Message pops up when i try to download tether to blackberry
Try to access the .jad directly by browsing to http://tether.com/t/tether.jad
I've found third-party sites hosting applications causing this error to occur on my 7100i
May 13, 2010 | RIM Sprint/Nextel 7100i Smartphone
CAN I TETHER THE BLACKBETTY CURVE 8350?
Yes you can, at least for verizon wireless tethering cost 29.99 on top of your plan, if you are interested please contact me at 815-931-8308 and ask for Dave i'll be happy to turn the feature on for you.
Apr 02, 2010 | Blackberry Curve 8350i
Lost registration code for AppleCare
You will need the original receipt of purchase for the APP. Then call 1 800 myapple and ask for assistance
Oct 31, 2009 | AppleCare Protection Plan for iMac/eMac...
I don't know how to tether my blackberry curve to my lap top
You also need to have PAM (phone-as-modem) Data Service through your provider Sprint no longer carries this unless you beg for it also you will need your carriers connection software on your computer.
Mar 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
