Question about Whirlpool AWM5104/1 Front Load Washer
No water I have cleaned both of the hose filters at the back of the machine but the water still does not get into the machine> When you start the cycle you can hear the machine sounding as if it is going to start but at no point does water get through If yiu turn the dial to drain, or spin etc these do work
  • gary campbell May 22, 2007
    I have replaced the cold inlet valve so water now comes.
    However the dial no longer turns on its own.
    We have to manually turn the dial for each cyle within the machine, we do notice a "clicking" noise as if it is to turn the dial, but it wont turn on its own
  • 5,911 Answers
Your problem sounds like a fill valve problem. This is what your fill hoses connect to on the back of your washer. It is an electric solenoid valve that is supposed to open when filling. However, sediments from hard water and well water have a tendency to clog them up to the point where they don't pass water any longer. Sometimes, the solenoid itself goes bad. A new valve usually runs about $20-$30. If you've checked your fill hoses and verified the household valves are working, then I recommend replacing the fill valve assembly in the washer. I hope this helps.
Posted on May 21, 2007
  • Jeff Rockwell
    Jeff Rockwell May 23, 2007
    If your timer isn't running on it's own then the timer is probably bad. There's a small timer motor that runs the various switches inside the dial. When the motor goes bad the timer does not advance. The motor is not serviceable and comes as part of an entire timer assembly. The timer is usually not cheap, either (anywhere from $100 to $200) Good luck.
SOURCE:
Washed some dirty runners & 2 small rugs on Daily Wash; came up with error code 5E cleaned debris filter any idea where water hose mesh filter is?
Usually on the back where hoses are attached to it . inside hoses are screens . turn water off ,unscrew the hose and check , then put hose back on tight .
Feb 14, 2016 | Washing Machines
How do I correct a 4E error?
try unpluging for 15mins re try
Apr 27, 2015 | Samsung Washing Machines
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
Explain erroe 4E
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jun 05, 2012 | Samsung WF337AA Front Load Washer
Describe your 4E problem in samsung front load Problem
Thanks for using FixYa!!
Sep 19, 2010 | Samsung WF203ANW Front Load Washer
Samsung model WF8602NHS showing error message 4E
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Sep 03, 2010 | Samsung WF306BHW High Efficiency Front...
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
I have a samsung i did a load of washing this morning with no problems when i put the second lot in it started beeping and is displaying 4e i cant find my book so i don't know what the problem is
Aug 02, 2010 | Samsung WF337AA Front Load Washer
Samsung B1245 front loader
Mar 15, 2009 | Samsung B1245 Front Load Washer
Cleaning bottom filter
You should be able to drain the water first using the small hose next to the filter knob. Sometimes the hose is plugged up, in which case you will spill water out the filter, or a better solution is to pull the washer forward a foot and a half, tip it back so the water goes to the back of the tub, then remove the filter, clean it, and reinstall.
Oct 03, 2008 | LG WM-2277HW Front Load Washer
Whirlpool AWM5104/1 Front Load Washer Logo
125 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
